Hydro - boost brakes
Are these brake systems bled the same way as regular brake systems ?
2004 Silverado Crewcab (Dark Spiral Gray) |
Re: Hydro - boost brakes
Yep.
The boost type does not affect fluid flow through the base brake system. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
How can you tell if one of these is bad
You can't stop lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
That's funny. On vacuum boosters, the pedal gets hard and very hard to stop. This pedal is not hard, in fact goes to the floor only like there is no PRESSURE. does stop but scared when it goes to the floor.
Does the pedal get higher when repeatedly pumped? If so then air in the system.
if not then sounds like master cylinder is leaking internally |
No it doesn't pump up, I just didn't know if these brakes were the same as the vacuum booster brakes
As far as I know the brake hardware in the wheels is the same,maybe differences in wheel cylinder diameter, but I don't know about the master cylinder of the hydro boost being the same as the master cylinder of the vacuum booster .
might surf to auto parts place website and get part number of each and see if they are the same. They might also may have picx |
my suburban has hydroboost and you bleed them just like vacuum brakes. I lost my brakes and found the master was leaking out the back.
