10-17-2012, 03:48 PM | #5151 |
Re: What did you do to your truck today!
fixed my guide plate and gave my tires a beating
10-17-2012, 03:50 PM | #5152 |
Replaced my battery, as well as the cables and terminals. Put in a new air filter and top.
Posted via Mobile Device |
10-17-2012, 06:49 PM | #5153 |
Old member
I pulled mine out of the garage so a guy could take pictures of it. He is building our mantel in the living room for us and want to show his dad my truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-17-2012, 07:35 PM | #5154 |
Collector of Projects
went to the pick-a-part yard... they only had one 71 LWB that was beat up and stripped... I did go by the S10s and pull some 175 amp main fuse blocks to eliminate the old fusbale link... I stole this idea from Whitels1 who did an LS swap on his square body K5 blazer ...
10-17-2012, 09:44 PM | #5155 |
Drove it. Enjoying the fall weather before it goes into winter hibernation.
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350 1966 Caprice 1968 Impala (Frame Off LSX Project) 2001 Tahoe LT 2013 Hyundai Elantra 2010 Kawasaki Z1000 |
10-17-2012, 10:12 PM | #5156 |
That truck is very clean looking, very nice ride you have.
10-17-2012, 11:18 PM | #5157 |
Thanks 69GWC!
10-18-2012, 12:19 AM | #5158 |
Junior Member
My son installed the Holley carb (1850) on the 454 in my '67 swb stepper and hooked up the linkage and fuel line. While I filled the radiator with anti-freeze.
We pushed the truck out of the garage and started the engine for the first time after putting it in the truck using a temporary gas tank. The mini starter I got from DB electric worked great without any shimming. The truck fired up after the fuel pump built up pressure. We ran the truck for a while until the thermostat opened and topped off the radiator.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
10-18-2012, 12:56 AM | #5159 |
I finally got both of my brake lights working with the lights on, replaced the one rocker arm that kept popping off the push rod, and over the weekend ended up getting the power steering put in and it drives like a charm now, finished painting it, and put side mirrors on that I picked up from o'reillys.
Edit: ill have to upload the pictures tomorrow, they're too big to upload from my phone.
1969 Chevy C10 250 straight six. Still a work in progress. |
10-21-2012, 01:08 AM | #5160 |
RAT1968 '68 Cab/'71 Parts
Just to prove to myself that I'll never be *done*, I decided to put in the new
M & H under dash wiring harness. So, in the course of doing that (and still trying to figure out why ALL of my gas gages don'e seem to want to play fair with the new sending unit), I broke the bezel. So, I bought a new one from a Seller on the Forum and filled it up again. Gotta go out and crawl around under the dash tomorrow, I guess. But I feel lazy.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
10-21-2012, 01:32 AM | #5161 |
What Tachometer is that ? .
So far no joy finding a 6 cylinder factory tach , one like yours will do , I just need to know brand etc. so I can go dig one up . TIA ,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
10-21-2012, 01:37 AM | #5162 |
Got my cooling fan brackets made and got them mounted to the radiator
Fuzzy |
10-21-2012, 02:02 AM | #5163 | |
10-21-2012, 08:57 AM | #5164 |
Re : Auotmeter Tachometer
THANX ! this means Kragen has it IIRC ......
10-21-2012, 11:11 AM | #5165 |
Old member
Drove mine 2 1/2 hrs one way to a car show in NC yesterday.
10-21-2012, 11:30 AM | #5166 |
Re: Re : Auotmeter Tachometer
Yeah. O'Reiley's up here in the North....But you better call 'em first. They have a display
of the tachs. But, up here, the local store seems to have to order everything. It's a 3 3/8" face. I think a model 5795, 6809, or 6811...but not sure. I just checked....There are 240 tachs on E-Slay just in case a Forum Seller doesn't one for ya.
10-21-2012, 05:53 PM | #5167 |
Junior Member
I sanded the dents and around them on my '67 cab and C10srule put bondo on dents that could not be popped out.
The repairs looks great. Next weekend we will finish sanding the cab and front clip. It is nice to have the truck running again so we don't have to push it in and out of the garage.
10-22-2012, 04:19 PM | #5168 |
Finished painting it and put the side mirrors on, the headlights are out because we have to replace them. We had to notch out a small piece of the fender well to have the lines clear for the power steering gearbox. We got the power steering pump mounted in with a few of our custom brackets that we had to make, but it definitely works extremely well. We might have to get another radiator hose because it looks like it's slightly touching the belt. And, I put a chrome oil breather on, a new air filter, and fuel filter. This is the ground wire that kept giving me my brake light problems and all I had to do was clean it and replace the screw and every light works now.
10-22-2012, 05:32 PM | #5169 | |
Re : 6 Cylinder Tachometer
Sunday I was doing my Physical Therapy in Pick-A-Part and stumbled across a cherry 1978 Jaguar XJ6 , I scored the tach for $13 and will see if I can adapt it to suit ~ I don't want a flashy guge , I want a stock looking one .
10-22-2012, 05:36 PM | #5170 |
Re : Power Steering Hoses
That radiator hose is too short . not to mention the crappo accordion typ .
Those P.S. hoses are wrong too , the corect ones are bent differently and clear the inner fenderwell easily . All these parts are available cheaply @ Rock Auto.com -Nate Quote:
10-22-2012, 06:04 PM | #5171 |
Pulled my leader hose because Im dumb and trashed it lol. This is what I did the other day! Happy Halloween!! Since the cops got called and tried to make me do away with my Halloween I said F it and didnt. I did put yellow tape around it like a crime scene.
10-22-2012, 06:11 PM | #5172 |
Filled it up with $3.19 a gallon gas... lol
10-22-2012, 06:36 PM | #5173 |
painted my frame.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
10-22-2012, 07:08 PM | #5174 |
Old member
I sanded and stripped paint off my 67 SS steering wheel.
10-22-2012, 07:25 PM | #5175 |
Grand PooBaa Member
