Old 10-18-2012, 10:04 AM   #1
rs72z
rs72z's Avatar
87 VIN issue???
My brother has a 87 swb 4x4 that the vin tag and the emission tag both show to have a 305. But the rpo sticker in the glove says it has a 350. Which is right?
The truck is original and appears that the engine has never been out, the truck also has original paint.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 10-18-2012, 11:06 AM   #2
Ski-me
Ski-me's Avatar
Re: 87 VIN issue???
What are the codes in question? RPO code that says 350 and what is the VIN number?
That might help narrow it down.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-18-2012, 11:15 AM   #3
Keith Seymore
Keith Seymore's Avatar
Re: 87 VIN issue???
x2 - agree. A little more detail would help.
Photos of the VIN tag, emission label and SPID would be great.
Keep in mind it's very easy to swap a glovebox, so check and verify the SPID goes with the truck you have.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-18-2012, 11:29 AM   #4
Ski-me
Ski-me's Avatar
Re: 87 VIN issue???
K
Good point. Verify that the VIN on the glove box matches the VIN of the truck. My first take, I would think it's a 350. I thought the 305 "phase" was in the early and mid 80's. 1987 was the first year of the fuel injection and the engines I'm aware of were 350's.
- Jeff
Old 10-18-2012, 11:54 AM   #5
Ski-me
Ski-me's Avatar
Re: 87 VIN issue???
Well, I guess 305's were offered in 87......
VIN Plate Decoding Information
1st Digit
NATION OF ORIGIN
1 = USA
2 = CANADA
3 = MEXICO
2nd Digit
MANIFACTURER
G = GENERAL MOTORS
3th Digit
MAKE
C = CHEVROLET
T = GMC
4th Digit
GVWR & Brake System
B = 3001-4000/HYDRAULIC
C = 4001-5000/HYDRAULIC
D = 5001-6000/HYDRAULIC
5th Digit
BODY STYLE
R = CONVENTIONAL CAB 2WD
V = CONVENTIONAL CAB 4WD
6th Digit
SERIES
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
7th Digit
BODY TYPE
6 = SUBURBAN
8 = BLAZER, JIMMY
8th Digit
ENGINE
H = 5.0L (305 CID) FI L03
K = 5.7L (350 CID) TBI LO5
C = 6.2L (379 CID) DIESEL MFI LH6
9th Digit
CHECK DIGIT
0 Thru 9 or X
10th Digit
YEAR H = 1987
12th to 17th Digit SEQUENCE NUMBERS
- Jeff
Old 10-18-2012, 01:20 PM   #6
Keith Seymore
Re: 87 VIN issue???
Yes - 305 was available in '87 as RPO LE9 (EFI/TBI).
K
1979-1986
1986 - 2019
Old 10-18-2012, 01:47 PM   #7
rs72z
rs72z's Avatar
Re: 87 VIN issue???
The vin code is H for 305 as is the emission tag. The vin on the spid matches the the vin on the truck but the spid list L05 = 350 tbi.
This truck is a original fairly low mile truck that doesn't appear to have been messed with.
___________________
78 ccsb dually
5.3
4l60e
Old 10-18-2012, 03:23 PM   #8
Keith Seymore
Re: 87 VIN issue???
I agree that H is the VIN code for the 305; I also agree that L05 = 350.
So - are you looking at the correct character in the VIN?
Position 8 is the engine code; Position 10 is the model year (which happens to be H for 1987).
Where does the emissions sticker attach (air cleaner? rad supt?)? Perhaps one of those components has been changed -
K
1979-1986
1986 - 2019
Old 10-18-2012, 04:03 PM   #9
rs72z
rs72z's Avatar
Re: 87 VIN issue???
H is the 8th and 10th digit. The emission tag is on the radiator support.
I run a collision shop and moat of the time i can tell if body parts have been changed. This truck doesn't apprear to ever have had a wrench turned on it. Everything on the engine is original best i can tell.
So is it possible that even with the vin and emission tag saying 305 but the spid saying 350 that it does have a 350?
Also i think all of the 305's in 87 came with a 3 speed trans and 350's came with the 700r4. This truck has a 700r4.
___________________
78 ccsb dually
5.3
4l60e
Old 10-18-2012, 04:22 PM   #10
64fleetside
Re: 87 VIN issue???
Which engine is actually in the truck?
64fleetside is offline   Reply With Quote
Old 10-18-2012, 04:29 PM   #11
rs72z
rs72z's Avatar
Re: 87 VIN issue???
That's what we are trying to figure out.
___________________
78 ccsb dually
5.3
4l60e
Old 10-18-2012, 04:31 PM   #12
64fleetside
Re: 87 VIN issue???
Drive it. Shouild be obvious.
Old 10-18-2012, 04:54 PM   #13
Ski-me
Ski-me's Avatar
Re: 87 VIN issue???
What about finding the block number? From my armchair research, it's located on the block, driver's side, back, on top of the bell housing flange.
Here is a site that might help deciphering it:
http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
- Jeff
Old 10-18-2012, 04:57 PM   #14
64fleetside
Re: 87 VIN issue???
Block casting number would eliminate any guesswork.
Old 10-18-2012, 05:07 PM   #15
Ski-me
Ski-me's Avatar
Re: 87 VIN issue???
A few years ago I was trying to find out what engine was in my 89' K5. I found the following info on my block:
So the numbers I could find:
Front passenger side just behind AC compressor - V1112UKA
Under side on block cast - 683
Under side on block towards the top -
627
56
N
The answer I got was:
V1112UKA
V = built in the Flint plant, 11 = November, 12 = 12th day of November, UKA = 1981 350 con. cab, m/t, A.I.R. P LF5 150 2 C-30 & 3500,159.5WB
The P LF5 is the partial VIN, the 150 is the HP rating, and the 2 means 2 BBL carb.
I think this site was used for part of the number above:
http://www.nastyz28.com/gm-chevy-cod...s-suffix-9.php
So basically, I guess I have an 81' block in my 89' Blazer.
- Jeff
