#1426 | |
Re: Make it handle
![]() The truck will still get the engine at least. Thanks again, Rob. You are such a wealth of info and your track record shows you at least have some idea what you might be talking about. ![]() <edit> And FYI, my car has zero rattles with the top on. Now if only the heater worked, I'd be golden.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#1427 |
Re: Make it handle
OK you've got me curious. I have a 86 c10 with an 5.3 LS, 4L60E, 4 wheel disc brakes, posi, front and rear sway bars. It handles pretty well for an old truck with 200 lbs of ballast just behind the rear axle. I have already dropped the rear end about 4 inches and cut 1 coil off the stock front springs. From a "low budget" standpoint, I want to run 2 1/2 inch drop spindles. For springs 3/4 ton with 1 coil cut off? Will the ride height still be a 2 1/2 inch drop or will the stiffer spring make it drop less? Is this a decent budget fix? Will the ride suck?
#1428 | |
Re: Make it handle
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247 |
#1429 | |
![]() Join Date: Jul 2010
Re: Make it handle
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#1430 |
Re: Make it handle
Thanks, it was a fun day. The seat belts crack me up.
#1431 |
Re: Make it handle
Hi Rob, Thanks for the reply. I am running stock rally wheels all the way around. 7 inch front and 8 inch rear. As of now it runs pretty flat thru the corners. Seems to have a bit of a push in the corner but not too bad. Using urethane bushings all the way around. I removed all but 3 leafs in the rear. Those left I shortened 4 inches and prepped with teflon pads. Has a Helwig rear sway bar stock 1/2 ton up front. Cheapy Monroe shocks. The rear end is a narrowed Ford 8.8( I know but it got me posi and disc for cheap)
#1432 |
Re: Make it handle
Goats86, sounds like a good set up. Tires will quickly become the limiting factor. I'm a fan of the Explorer 8.8, lots of value there. Try and dig up some stock 1/2t front springs, and start out by swapping the spindles and putting full height springs back in. Check the ride height. This will lower the CG, but, will probably raise the roll center. The truck will feel more stable, but the higher roll center may add to the push givin your front tire. For some extra drop out back, try a raised front spring hanger. This will also help by raising the anti-squat % a bit. Try to make one change at a time so you can note the changes. - let us know.
#1433 |
I've got grease on my mind.
Re: Make it handle
Oh my gosh! I caught up to the rest of the class. Lots of great info.
Thanks for doing this Rob and everyone else who has been helping out with information we all need to know. As we were talking about shocks I was wondering if these were your front reloction brackets I saw on a 68 CST. They look kind of like your rears except they are not painted "Battleship Grey". If they are yours what do they cost and if not, can we get info on the front bracket you offer? What about moving the shock into the center of the spring like every other car has? Is this just too much work or is there no real benefit to spending our time and money there? |
#1434 |
![]() Join Date: May 2012
Re: Make it handle
Rob is there a picture of a good g frame for a 56 chevy truck that you could post. I have installed a 76 camaro sub on my extra frame and cnoched the rear, I just picked up the plates to plate benind the sub to the middle cross member, I just read on one of the first post on this thread about skipping the welds (2" weld skip 4") I was doing to window the plates to remove wt. Then in a post you suggested to use tubes 1 1/2 .120t to build 45 angles, is that w/ plates or without. Thanks for being on here.
#1435 |
Re: Make it handle
Rob! I'm back and almost ready to start on making more suspension improvements. I know I'll have to go back and read up on anti-squat, anti-dive, roll center and so on but I wanted to ask a question.
Your thread has covered bump steer. You mentioned heating the steering arms and bending them back down to correct bump steer. I have obtained a new set of lower cross shafts and intend to have them drilled at 90 degree intervals to obtain 1/4 inch increments for alignment machine testing (stock, 1/4", 1/2" and 3/4") I want to take my upper cross shafts to a local machine shop to have the holes milled so as to elongate the holes as much as THEY feel comfortable with doing (you mentioned 7/8"). I also have a set of spindles going to the scrap pile that I wanna steal the steering arms off of. I want to prep by attaching a string from the t/r end at the steering arm to the t/r end on the other side and measure from that string to the frame to eliminate tire size. Do you have any info regarding where the arm should be for "correct" bumpsteer?What is your advice on heating the arms? More along the lines of cooling...Do you like to quench or cool naturally? ***EDIT*** This coulda read a lot better than I typed it out but I think you get the idea. To simplify, Is the "stock" steering arm position a good base line to keep for experimental purposes or is there a better starting point? How do you prefer to treat heated suspension components?
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! Last edited by BMERDOC; 10-26-2012 at 08:44 PM. |
#1436 |
Re: Make it handle
Wow....took me 4 days to read it all....holy cr@p alot of great info.......thank you!
Couldn't come at a better time.....I'm in the planning stages of a new build.....1973 C20.....going to do my best to apply as many of the lessons learned in this thread to my 8lug ![]() Posted via Mobile Device Last edited by moregrip; 11-02-2012 at 03:29 PM. |
#1437 |
Re: Make it handle
i often haul a couple dirtbikes in my truck so i can only soften teh back so much. i have an short square with a flip kit, drop shackles and notch. i have about 4-4 1/2" between the axle and frame with 5 leafs and the overload. I was thinking about removing the overload and 2 smaller leafs and then putting junk yard helper leafs on it. would this be helpfull and how much travel would i want before the helpers begin to be used?
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#1438 |
Re: Make it handle
i plan on getting 3/4 ton coils and putting my 1 1/4" bar on. i also need to find a rear bar
#1439 |
Re: Make it handle
i guess i wouldnt be able to do that with the flip kit. maybe i can figure out a way to use helper coils. probably should have so many "late night ideas"
#1440 |
Re: Make it handle
quagruple post
i had 5 leafs and an overload, i now habe the 2 long and the bottem with the overload. it rides better for sure and now its level. i think im bottoming out the longer shock i have on the back
#1441 |
Re: Make it handle
http://www.ridetech.com/store/1973-8...hq-series.html
Rob have you tested this line of shocks at all? You recommended fox shocks and they say these are them. Either way these are what I'm planning on running unless you have a better one in mind? Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#1442 | |
Boosted Member
Re: Make it handle
They look to be a very high quality unit.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#1443 |
motor exploder
Re: Make it handle
Rob (or anyone else), do you have any thoughts on using ball joint spacers to make the spindle act 'taller' for camber gain?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#1444 |
![]() Join Date: Apr 2008
Re: Make it handle
I don't have the Ride-Tech shocks but I have the Bilstein version. The important thing is that they are the mono tube type, they work very well and I am very happy with the performance and their ability to control the bumps and curves. Handles great for a big heavy truck.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#1445 | |
Re: Make it handle
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#1446 | |
Boosted Member
Re: Make it handle
I just finished mine up this weekend... ![]()
#1447 |
A guy with a truck
Re: Make it handle
Curious, too. What about taller upper BJs?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#1448 |
Re: Make it handle
Ok, sorry I've been away for a bit. SEMA and the fal show set have me runnin.
Yes, the RideTech coil overs are made by Fox. We use them, currently on the HellBoy, and they are a very good shock The Bilstien is a nice piece. The 'inertia' valve is pretty hi-tech, soft at low speed, and firms up quickly at higher motion rates. This makes it a great all-around shock. Ball joint spacers?? don't know. But, "Tall ball joints" can help. This effectively adds to the "camber gain", and may raise the roll center a bit. Lots of NASCAR hobby racers use GM truck ball joints because they are stronger than the car units. Check out HOWE racing or Speedway Motors.
#1449 |
Re: Make it handle
Last week we swapped out our 'home modified' LCA on the JT for a set of Nate Porter's "Forward Lower" arms. I'm getting the picts together and I'll post up the info here and on the JT thread.
#1450 |
Re: Make it handle
During the Scottsdale GoodGuys show, we went over to Dino's friday night 'get together'. Pretty impressive. A lot more trucks than I expected, and some really cool ones. Dino is a great guy for hosting this event, including drinks and food. Thanks again Dino, we had a great time. - Expect to see some picts in Street Trucks soon.
