lift cab off frame
how is the best way to lift the cab off the frame,, any pics,, all i have is a cherry picker,,,, and other ways,,,,, i dont have that many buddies,,hahahah.
72 swb pickup http://i124.photobucket.com/albums/p...k/100_0958.jpg 1967 chevelle ss 1966 mustang getting a l33 ls motor 1969 chevy dump truck 1989 mustang 6.0 ls best time of 1.29 at 5.91 https://www.youtube.com/watch?v=JtbooZoGZmQ |
I am a Referee of life.
Re: lift cab off frame
Do a search for a Cab/bed lift.Someone on this forum has posted a how to on making a jig to do this with a cherry picker engine hoist.Quite a few members have used it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
We just did this, three times. Three guys, one on each side near the rear and one in front.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I made one out of a 4x4 and some 2x6. It works fine and was free.
![]() ![]() Join Date: Jul 2002
Yep. Cherry picker works great.
If you still have the glass in or other stuff it will be very front heavy. You'll need to strap (orange one in my pictureit so it would roll forward. You probably should even have enough lift with yours being a 4x4 (I assume anyways), but you may want to take tiers off and drop it low on jack stands. I used what I had. Couple 2x4s tie straps, towels and duct tape. It held up great and worked smooth as silk for a 1 man job.
Old Skool Club
![]() Join Date: Jun 2001
4 of us lifted my cab, and it was gutted....no glass or doors.
As for lifting it with the glass still in it....the weight bias is toward the firewall, so you gotta compensate. Pay attention to the pix of the cherry picker and the placement. That was right.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Aug 2007
I just put a strap through the cab, hooked my cherry picker up above the cab and lifted it off, rolled the cherry picker out and set it down, the doors and everything was removed before I did it too. it was really easy, just steady it with your hand when you get it lifted off. Oh and I removed the wheels and tires and had it on jack stands.
Scotts72C10 |
![]() Join Date: Feb 2012
I jacked up my frame, made a jig the bolted to the door hinge area and doors striker plate. I then let the frame down and rolled it out from under the cab. I can now roll the cab around. I belive thre is a pic in my post.
A couple 2x6s and some 2x4 scraps. copied a design from others here but use 2x6 for overkill. 1 lag bolt to tie the upper together and 1 bolt through the lower extension through the hoist eye (remove the chain). Used a ratchet strap to tie the rig to my engine hoist so I wouldn't have to worry about balancing it. I can get you some measurements if you want. All by myself
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
i like that send them my way,,, thanks
No prob I will get some measurements and a drawing for you tomorrow.
on my truck, me and my brother in law hooked ratchet straps to each corner of the bottom of the cab, put the straps over our shoulders and lifted it off. then my dad pushed the frame out from underneath and we set the cab on sawhorses
I used eye bolts screwed into the bolt holes for the fenders and bolt holes for the gas tank, then attached 3 ratchet straps that I hung from the rafters in my garage and lifted at each strap a little at a time.
![]() Join Date: Jul 2007
I made a bracket to fit on my picker that holds a 4x4. I can pick it up and move it around easily. I also made one of those cab /bed lifts for my lift but sold it when I was done with a cab move on a project. Both work well.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#15 |
Man there are some other good methods too, I like that eye bolts method from itsRandy. Nice!
Here are some measurements of mine. Note the ** on the left. I had to turn the end 2x6 to clear the hoist as you can see in the second pic above. Also I used a variety of 3 and 4" wood screws depending on how many 2xs I was screwing through. I predrilled all screw holes so the wood would not split. If you have any Qs just let me know. another note if you move the hoist eye position away from you it will move the center of gravity toward you so the cab will tilt toward you as opposed to away from you. Still I used the strap to make sure it didn't tilt away and slip or fall. EDIT: for some reason the long 2x6 dimension is fuzzy. it is 68" 2x6
#16 |
I used chains thru the cab mounting holes and seat belt holes.
69 C-10 in progress |
#17 |
![]() Join Date: Nov 2007
i like that idea rogue willie, ill have to use that
#18 |
![]() Join Date: May 2007
Lots of good ideas.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#19 |
![]() Join Date: Oct 2012
great idea with the cahains, weve always strapped a 4x4 to the top of our cherry picker, will try the chains next time looks more stable
#20 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
