10-20-2012, 03:37 PM | #1 |
wilwood prop valve issues
Folks,
My proportioning valve is not letting fluid go to the rear brakes. It seemed to be working when i first put it in, but not now. I took it apart but can't be sure if it is working.....I have fluid to the "in" from the master cylinder but the valve seems to be going bad....anyone experience this? |
10-20-2012, 08:01 PM | #2 |
Re: wilwood prop valve issues
The way i solved this problem I plugged one half of the M/C and worked on one end at a time by bleeding the wheels until I had a good pedel and fluid.
I then hooked up the other half and bled that end until I had good pedel and no more air. Get a good helper and another quart of fluid, you can do it !!
10-20-2012, 09:42 PM | #3 | |
