Old 10-23-2012, 05:36 AM   #1
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Tie rod end help for drop spindle installation
I installed a set of drop spindles on my 71 2wd Blazer- These use the 73 & Up larger taper outer tie rod ends. I have done several of these in the past and rounded up a drag link setup from a 73& up donor. The junkyards here are now not quite as numerous-
so what's the alternative?
Is there a tie rod sleeve that replaces the 71 model and allows the 73 & up outer? Part number and supplier if anyone knows- if not, I guess I'll make the junkyard run- Thanks
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 10-23-2012, 12:36 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Tie rod end help for drop spindle installation
Chuck....have you looked on this awesome post by lolife99?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-23-2012, 08:48 PM   #3
chuckmc8
chuckmc8's Avatar
Those are great- I was hoping someone who had bought the adapter sleeves could post a part number and price
Old 10-23-2012, 08:57 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
71-72 tie rods are the same diameter as 73-87 (11/16")
You can use a 71-72 centerlink with a 71-72 inner tie rod connected to a 73-87 outer tie rod.
I would think a 73-87 centerlink would be easier to find.
But your original 71 2wd blazer center link will work just fine.
Keith
Convert to disc brakes.
Old 10-23-2012, 08:59 PM   #5
lolife99
lolife99's Avatar
The adapter sleeve is for the smaller tie rod 67-70 centerlink.
These tie rods are 5/8" diameter.
Plus they are the wrong thread direction.
To make this work:
1) 67-70 centerlink
2) 67-70 outer tie rod in the inner location
3) adapter sleeve
4) connected to a 73-87 outer.
Keith
Old 10-24-2012, 05:43 AM   #6
chuckmc8
chuckmc8's Avatar
Thanks Keith. So, I just need to order a set of 73-87 outer tie rod ends and I am in business?
Old 10-24-2012, 07:39 AM   #7
lolife99
lolife99's Avatar
Yes.
Keith
