Old 10-23-2012, 10:53 PM   #1
ibhebel
bagging a 1966 chevy truck
im getting ready to bag along bed fleetside 66 chevy truck. How do i determine what size bags to use?
ibhebel is offline   Reply With Quote
Old 10-24-2012, 04:21 PM   #2
shooter64
Re: bagging a 1966 chevy truck
Weight of truck. A lot of people say 2600. I have 2500s
shooter64 is offline   Reply With Quote
Old 10-24-2012, 08:08 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have used two chamber bags in the front of my old 65, but I hear single chamber in the front is better to keep down body roll. The single chamber bags will be shorter and less range of movement.
At some point I plan to bag the front of mine and will go with single chamber bags.
AS far as weight rating, is 100# really going to make a difference? I would say 2500 and 2600 would work fine. If you are running a V8, I would go with 2600# just for the little extra load cap.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-25-2012, 09:56 AM   #4
blazins10
blazins10's Avatar
2600 in the front , wither 25 or 26 in the rear
always put the the biggest bag u can in because
u get more lift with less psi and in return its a more comfy ride
also works in in reverse too smaller bag = more psi firmer ride
i have 2600 in all four
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 10-25-2012, 11:17 AM   #5
scum1
scum1's Avatar
I have 2500's all around. I cupped my LCA's so I didnt want to have any rubbing issues with the bigger bag. Now that its all said and done, i PROBABLY could of used the 2600's up front, but the ride is still pretty sweet. Something to consider if thats the route your going
scum1 is offline   Reply With Quote
Old 10-25-2012, 12:20 PM   #6
CRGRS 66
CRGRS 66's Avatar
I have ordered a porterbuilt kit from Pro Performance is AZ, it is a simple kit so that I can adjust my ride height if I have a load, or am towing my camper (no C-notch). There is a picture of the kit in my build thread.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-25-2012, 08:19 PM   #7
Pro Performance
Pro Performance's Avatar
Most bags kits will run the double convoluted bag, which does have more travel. A lot of the kits we sell will use the slam specialties SS7 bag, which is a good all around bad. They also have built-in internal bump stops which is a nice feature.
Craig,
Just checked out your build thread.... It is looking good.
Pro Performance is offline   Reply With Quote
