Old 10-24-2012, 05:21 PM   #1
weever82
weever82's Avatar
What shift linkage kits are you using?
I am in need of replacing my shift linkage/rod in my 69 with a TH400. The new tilt steering column is coming and the old rod/linkage has seen better days.
Who makes the best kit for the TH400 in our trucks. Seen a Kugel Komponents that looks nice but heard that you needed to bend the rod to get the right angle...
http://www.kugelkomponents.com/zenca...&products_id=7
Thoughts? As always, thanks for your guys time!
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 10-24-2012, 08:56 PM   #2
Daaaanz67
Re: What shift linkage kits are you using?
Kugel for me yes I had to bend the rod. I just used a coat hanger for trial fitment and transferred the bends
Daaaanz67 is offline   Reply With Quote
Old 10-24-2012, 10:04 PM   #3
weever82
weever82's Avatar
Thats what I thought, great idea on the coat hanger! Was the install pretty simple? I have never messed with tranny linkage before.
Thanks.
Weev-
Weev-
Old 10-24-2012, 10:22 PM   #4
Duvall
I used the Lokar linkage. Worked great and just had to put a slight curve in the rod.
Duvall is offline   Reply With Quote
Old 10-24-2012, 11:41 PM   #5
Daaaanz67
I was kind of nervous doing this. Then after using the coat hanger double check triple check everything before bending it turned out to be simple. I also made sure that after I put the adapter lever on the tranny side, I moved the adapter lever through its range to make sure it didn't hit exhaust. Do this with the hanger on your mock up also.Here's mine
Old 11-08-2012, 07:48 PM   #6
weever82
weever82's Avatar
Forgot to thank you for the pics! I just ordered the Kugel long polished shift kit today so will just bend it to fit and hopefully look/perform better than the one on there now.
Weev-
Weev-
Old 11-08-2012, 08:13 PM   #7
Daaaanz67
No problem take your time and that's no wimpy rod That you will be bending quality stuff.
