Old 10-18-2003, 09:24 PM   #1
krazy_texan
krazy_texan's Avatar
New tranny filter and oil
Today i decided that i was going to change my oil and transmission filter since i have no idea when it was last changed, the motor only had 3 quarts of oil in it and i dont have any idea how it got that low and then the transmission pan was a pain in the arse because of the 2 bolts on the back that you cant get a socket on because of the trans crossmember but now the truck runs like a top, tommarow i am going to clean the truck out and put new alt belt on it, sounds like fun but i thought that i would just share what i have done and what i am doing.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-18-2003, 09:40 PM   #2
rage'nrat638
rage'nrat638's Avatar
i wish thats all mine needed
rage'nrat638 is offline   Reply With Quote
Old 10-18-2003, 09:40 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
Truck work days are always fun
I played with mine for a little bit today, but accomplished nothing. I tried to replace a tie rod, but couldn't get the old one out. Then i inspected the brake caliper. The brake pull seems to have disappeard now...maybe it is becuase i despertly need a front end allignment, and the eyeball allignment i gave it is pretty accurate
Even though i didn't acomplish much, i still had fun. It feels good to get grease under your fingernails sometimes
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-18-2003, 11:12 PM   #4
krazy_texan
hey yellow72custom did you try smacking the $hit out of joint of the tie rod, hit it on the side not from teh top or bottom and dont try to pry it off
Krazy Texan
1990 v1500 suburban
Old 10-18-2003, 11:27 PM   #5
lukecp
lukecp's Avatar
I tried smacking it in most ways posssible, and added some heat from a propane torch to the equation, but i still couldn't get it off, lol. I already have the truck back together with the sub-par tie rod still in use, so it will have to last for awhile. I'm just going to take it somewhere to get it done, since i really don't have the time or place to work on it unless i am at home for the weekend....But that is OK though
Old 10-18-2003, 11:38 PM   #6
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Were you using a pickle fork?
Cat Fuzz is offline   Reply With Quote
Old 10-18-2003, 11:41 PM   #7
lukecp
lukecp's Avatar
Yes, the manual kind....didn't help though. A pneumatic pickle fork would be nice
Old 10-18-2003, 11:47 PM   #8
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Get you a 3 pound one handed sledge. Don't be afraid to really smack it.
Old 10-19-2003, 03:39 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Whene dropping the tranny pan, if you use a 1/4 inch drive set, you can normally get those bolts off uf you use a universal.
Old 10-19-2003, 10:26 PM   #10
krazy_texan
i just used an open end and held it perpindicular to the bolt, took me a while but it worked
Krazy Texan
1990 v1500 suburban
