10-18-2003, 11:21 PM | #1 |
front anxle
I have a front axle out of a 76 chevy 4x4. It looks like a dana 44 but it looks bigger and the axle is not centered like the 44 more off set and lower. I did see any marking on the axle I wonder if this is a Dana 66. Any suggestions.
Thanks |
10-19-2003, 12:24 AM | #2 |
If the axle is a dana 60, the easiest way to tell is to look at the u bolts. if there is only one u bolt on the diff, and 2 studs, then it is a 60. if there are 2 u bolts, it's a 44. hope this helps
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
10-19-2003, 01:56 AM | #3 |
To my knowledge GM did not manuf. a 1 ton in '76 unless somebody did a retro install on the truck you have. Yea check the bolts on the pass. side to make sure.
10-19-2003, 10:19 AM | #4 |
user # 2756
Could it be a swapped in high pinion dana60 out of a ford? Mor than likely a dana44 though.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
