10-25-2012, 03:58 PM | #1 |
Panel Light Help
My panel lights are not working I checked the fuse and its good but no power to the fuse I'm thinking its supplied by the light switch when lights are on. So if I replace the switch would it fix the problem? Any info would help.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=531265 72 Cheyenne Super 90 Z71 S.B. 434 C.I. Stroker 78 Camaro Z28 (gave to wife she is restoring it) |
10-25-2012, 06:41 PM | #2 |
Old member
Re: Panel Light Help
Have u checked the plug in on the back of the dash. Make sure it's in tight. There should be a seperate ground wire to the dash also make sure it's good. Does anything work in the dash? U may have a tear in the circuit board to which would keep the lights from working.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-25-2012, 06:46 PM | #3 |
Try turning your dimmer switch slightly to see if anything lights up. The dimmer part of the light switch is simply a resistance coil and I have seen many burned out in the full bright position. Turning it a bit might illuminate your panel.
10-26-2012, 06:32 PM | #4 |
tried turning the dimmer no help. ran power to fuse and they work. so figure it might be the switch.
10-26-2012, 08:40 PM | #5 |
Old member
If you ran a new power wire to the switch and turned the switch on then it would be the wiring to the switch I would think. Not the switch. Check the wires from switch back to fuse panel.
10-27-2012, 12:42 PM | #6 |
I ran power just to the panel light fuse in the fuse box. The switch has power headlights and marker lights work including the interior light.
