Old 10-25-2012, 04:11 PM   #1
Dale99
Grease fitting on hub??
So on my right front hub, I have what looks like a grease fitting thats been rounded off. Its only on my right one.
Is this from a different year on the right, left been replaced, or something a previous owner has done?
Its preventing me from putting the wheels I want on the truck. So I'm trying to decide to remove n plug. Or find different wheels?
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 10-26-2012, 09:10 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Grease fitting on hub??
Do you have a picture? Sounds like a PO modification.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-26-2012, 10:24 AM   #3
Dale99
I can get one tonight.
Old 10-26-2012, 05:52 PM   #4
Dale99
1994 s10 blazer 4x4
Old 10-26-2012, 06:07 PM   #5
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Never seen that before on a front hub but any replacement grease zirk should screw right in there. Just have to unscrew the zirk any time you want to remove the wheels. That zirk is not rounded off, the head is broke off.
DirtyLarry is offline   Reply With Quote
Old 10-26-2012, 06:23 PM   #6
Dale99
I just want it out that way. If its not suppose to be there, I will remove it and fill it.
Old 10-26-2012, 06:44 PM   #7
OLDCHEV4X4
OLDCHEV4X4's Avatar
Yea, thats not supposed to be there. I would remove and weld the hole shut.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 10-26-2012, 10:12 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I bet someone drilled & tapped a hole for the zerk so they could grease the wheel bearing without taking anything apart.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-26-2012, 10:18 PM   #9
Dale99
Thats what I was thinking Stocker.
Its removed and plugged for now. When I rebuild the front, I will see if this spare that came with it is good and replace it.
Old 10-27-2012, 03:01 PM   #10
V30 mongo
Did that on my 88 V30 dual wheel CC, but with the dual wheel rim, the zerk is inside, behind the wheel. A couple shots of grease every so so, and the grease gets into everything without taking it apart. Don't know how it would work a a single wheel system. Also did the same years ago on a 77 Scout. Had to counter sink the zerks to allow the wheel to go on and off.
V30 mongo is offline   Reply With Quote
