10-25-2012, 05:27 PM | #1 |
250 motor
so ive been looking for a 250 inline 6 to put in my truck. what all did these motors come in and how hard is it to find them?
10-25-2012, 10:53 PM | #2 |
Re: 250 motor
They came in many 66 up cars & trucks. After 1975 the trucks started useing an intregal head model. Stay away from it.
It seems they are all over the parts for sale sections of the old truck websites. |
10-26-2012, 01:22 AM | #3 |
Re: 250 motor
I have a 76 model with H.E.I. and it performs well unless I tow our 3,000 lb trailer up a hill and then the 3:08s and the sm 420 suck eggs. I'm sticking with the 250 and have sourced a newer 3:73 rear along with a 700r4 that's ready to go in as this Winters project. Should make the 250 happier pulling a load.
Posted via Mobile Device |
10-26-2012, 07:46 AM | #4 |
Re: 250 motor
thanks guy i have a turbo 350 im planning to put behind one and 3.73 gears in the new rear end i have for it
10-26-2012, 08:04 AM | #5 |
Re: 250 motor
Just finished a mild 250/2004r swap in my 51 3800. It is sweet 60 to 65 no problems,even with a 4:10 gear .Lots more left in it , and the milage is a lot nicer than the 235 and SM420 I had . Lots better
10-26-2012, 09:52 AM | #6 |
Re: 250 motor
what are you getting for mileage? thats a main reason why im trying to get rid of my 235, that and my turbo 350 wont bolt up to it without the adapter plate. just to clarify, but cant the turbo 350 bolt right up the the 250 with no problems or adapters?
10-26-2012, 10:10 AM | #7 |
Re: 250 motor
Any time you use an automatic trans mission you lose fuel mileage.there is just more drag in planatary gears.
10-26-2012, 11:26 AM | #8 |
Re: 250 motor
yes, 350 will bolt up. If you are going that far, swapping engine and trans, why not a 700r4 and be done!
"Any time you use an automatic trans mission you lose fuel mileage.there is just more drag in planatary gears. " Yes, Unless the engine is smaller displacement and the gearing is too low in a heavy rig, working the engine harder at desired speeds. Like a 235 and an old 4 speed truck trans I had helped with a 235 in a 55 car, Buffalo adapter to a 200r4 (same rear diff) and milage improved over the 2 speed powergilde. Completely different vehicle , but similar example Last edited by NEWFISHER; 10-26-2012 at 11:34 AM. |
10-26-2012, 02:48 PM | #9 |
Re: 250 motor
Around 18 mpg so far. And it will actually pass something and not act like its gonna die. I am looking at the turbo thread from the 60-66 thread . That looks intresting as well.
LMD |
10-27-2012, 12:44 AM | #10 | |
Re: 250 motor
10-27-2012, 01:16 AM | #11 |
Re: 250 motor
Perfect for 4x. Makes a shorter combo and you can double the 205 with a 203 for lower tcase gearing and have a longer front driveshaft for a better angle if you are lifting it. If its stock hieght and not going crazy with big tires etc then a 700r4 would work and give you better highway gearing.
10-28-2012, 12:59 PM | #12 |
Re: 250 motor
As pointed out above, any transmission which prevents the engine from operating at it's most efficient point for the longest time is wasting energy. In that case swapping to a less efficient trans can make for a more efficient vehicle.
If you end up choosing a 250 or even fall into a 292 you might want to consider the powertrain as a whole. The 250 has a similar bore and stroke to the 305 but is more limited in airflow so it's not the greatest for mid range power. A towing or RV cam is a good way to shift the power curve toward the lower rpm ranges. I think the 3.73 isn't a bad choice for a rear gear but if you're carrying a large load or moving a big truck / big tires you might want to get a torque converter with a high torque multiplication ratio to help the engine at low rpm. Some of the diesel converters have very high multiplication ratios along with low stall speeds but there are also specialists that build whatever you want. The 700R4 actually has a really steep 1st gear ratio which can be helpful for offroad or towing but there are other ways to add gearing if needed and the THM350's a decent, reliable trans. |
10-28-2012, 09:39 PM | #13 |
Re: 250 motor
Thanks guys always appreciate the wealth of knowledge you guys share. id be lost without it on my build
10-29-2012, 11:58 AM | #14 | |
Re: 250 motor
