Old 10-26-2012, 04:24 PM   #1
SeeTen
SeeTen's Avatar
Where does your ammeter sit?
Hey all!
As the title would suggest, I just got to fixing my non-woring ammeter by simply replacing the two SFE 4Amp fuses in the engine bay. The gauge used to sit right in the middle and not move a bit, but now it sags down when cranking and jumps up past the middle once it's all fired up.
My questions is, where do your ammeters sit? Mine is just about half a centimeter above the middle at idle - I was expecting a more sizable jump than that. Anyone have an ammeter that acts differently?
Thanks a bunch!
SeeTen is offline   Reply With Quote
Old 10-26-2012, 06:33 PM   #2
SS Tim
SS Tim's Avatar
Re: Where does your ammeter sit?
Sounds loke it is working fine. Think of the center as a balance point. When it starts trending to the left you are using more than yoou are making. Not bad when you are starting but something to watch while you are driving. When it goes the other way the alternator is making more than you are using and thus charging the battery. When you start moving this is a good thing. If it stays there or climbs while driving time to look things over. Now there are times like sitting at a light with the blower or A/C going along with the lights that the needle will really sag but start working its way back to center. This just is showing the system is working but if it gets worse over time your battery might be going south on you.
SS Tim is offline   Reply With Quote
Old 10-26-2012, 07:57 PM   #3
71K20chevy
71K20chevy's Avatar
Honestly I never notice mine moving at all
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 10-26-2012, 08:30 PM   #4
Andy4639
Old member
Andy4639's Avatar
Cool Re: Where does your ammeter sit?
You have to remember these are current flowing meter's. So as stated when u crank the truck you are drawing from the batteries reserve. Needle goes down until the truck starts then the alternator kicks in more current flowing to build the battery back up. Needle should go back to the right of mark.
This is normal and it barley being to the right of the half mark is correct for a good charging system. If you watch it real close turn everything on high and see if it doesn't drop then pick back up. Then turn everything off and it should go back to normal barley over the half mark. It's showing the system flowing either good are bad depending on the needle reference to the half mark on guage face. To the right is good and to the left is bad if the truck is running.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
