Old 10-19-2003, 06:08 PM   #1
skokie
skokie's Avatar
Converting a 3 on the column to auto
I have been looking for a steering column for my 68 chevy. I want to convert it from auto on the floor to on the column however since I am new at this this I need to know what I will need. I am shopping around for the column steering wheel down. Is there anything else I will need?
Thanks in advance
Brad
skokie is offline   Reply With Quote
Old 10-19-2003, 06:48 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You need the shift linkage pieces that go from the column to the tranny. The factory stuff is several pieces that bolt to the frame, tranny, and between the two.
I always use these though. They cost 40 dollars and work scads better than the factory stuff. Looks trick too.
GET IT HERE
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-19-2003, 06:51 PM   #3
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
dont forget the auto x member and trans lines/cooler you will have to remove the 3spd crossmember
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 10-19-2003, 06:54 PM   #4
Tx Firefighter
I had a big thing typed up with all that he needed, including, mount, flexplate, and cooler, lines, etc, till I noticed in his thread that he wanted to convert his floor shift auto to a column shift auto. I'm confused now.
Old 10-19-2003, 06:56 PM   #5
skyhawk1
skyhawk1's Avatar
Or, you can do the "Red Neck" Way. Just use one of the 3-speed shifter levers. I did it that way (don't remember wich one I used) and it worked just fine. Just be careful when you start it because it will start in any position.
"The World's a Mess"!
71 C-10
72 Suburban 2WD
Oceana, West Virginia
skyhawk1 is offline   Reply With Quote
Old 10-19-2003, 06:59 PM   #6
skokie
skokie's Avatar
Tx Firefighter
I am confused as well Originally the truck was a 3 on the column, Previous owner put in a new 400 turbo tranny and disabled the 3 on the column. What I am looking to do is make it an auto on the column and patch the hole in the floor that was cut for the floor shifter.
Ok now I am confused to
Brad
Old 10-19-2003, 07:02 PM   #7
Tx Firefighter
That's real simple then. Bolt in the column and hook up a linkage to it. Either stock or aftermarket linkage.
By the way, if you post on the parts board looking for an auto column, you'll find plenty offers to sell you one, as long as you don't want a tilt that is.
Seriously, that linkage kit above is the bomb. It's all new and UPS man delivers it in a few days. Way easier than rounding up a stock setup usually.
Kevin
Old 10-19-2003, 07:23 PM   #8
skokie
skokie's Avatar
Thanks Tx Firefighter. I have my eye on a column on ebay and I asked a bud of mine who was heading to a salvage yard to have a look as well. Other than the linkage and the column mounting itself is there anything else I will need? Very new to this stuff and I am learning as I go.
Old 10-19-2003, 07:25 PM   #9
Tx Firefighter
Column and linkage will do it.
Be careful of ebay steering column. There are plenty of guys here who will sell you a column cheaper than what they go for on ebay, and you support a board member too.
I bought mine from a fellow member here (Ratrod) for 25.00.
Old 10-19-2003, 07:26 PM   #10
skokie
skokie's Avatar
Gotcha. Will watch them. Btw is there a difference if i decide to go with a tilt wheel?
Old 10-19-2003, 07:29 PM   #11
Tx Firefighter
Tilt and no tilt will interchange.
Do a search on here for "van column" and you'll find a way to get tilt for cheap. Requires a couple of real simple changes. Last one I put in took about 2 hrs total including doing the minor mods required.
Old 10-19-2003, 07:30 PM   #12
skokie
skokie's Avatar
Will do and thanks again. Am sure to have more questions later
Brad
Old 10-19-2003, 07:31 PM   #13
bigvinnie
bigvinnie's Avatar
not much difference other than price and "cool" factor...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 10-19-2003, 09:12 PM   #14
Bryan68custom
Tx Firefighter can that linkage be made to work on a power glide , my linkage is getting sloppy
2004 Extended cab LS silverado
2001 Buick Lesabre
1968 Chevy Custom 10 LWB Anniversery model
2008 crew cab lt (rolling on dubs)
"The nice part about living in a small town is when you don't know what you're doing, someone else always does"
Bryan68custom is offline   Reply With Quote
Old 10-19-2003, 09:14 PM   #15
Tx Firefighter
I don't know. Try calling Kugel Komponents. They're usually very helpful on the phone.
Old 10-19-2003, 09:19 PM   #16
Bryan68custom
Thanks I'll try them tomorrow from work.
2001 Buick Lesabre
Old 10-20-2003, 04:28 PM   #17
skokie
skokie's Avatar
Well I called the guys at Kugel and placed a order. Now to get a column. I found a salvage yard that has these trucks. Thats all they do so I guess its time to hit the boneyard
Thanks for all of the help.
