View Poll Results: To air condition or to not?
Add A/C to the build 8 88.89%
Not worth the money 1 11.11%
Are you nutz? 0 0%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
Old 10-29-2012, 01:47 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
5.3 with a/c question
I am goin to be converting to a LS based engine soon, i am thinking probably a 5.3, my 70 c10 has never had A/C do you guys think it would be worth investing in it?? I would probably use A/c parts off a 99 or newer truck, to prevent from doing a R12 conversion.
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 10-29-2012, 07:57 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 5.3 with a/c question
I put the whole system in mine and haven't looked back. It's one of the nicest mods I've done to the 71. You want regret it. Don't know how much of the 99 stuff will fit but the compressor will with the right mounts.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-29-2012, 08:06 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
If it is originally a NON-AC cab I would buy a kit from Vintage Air. I would purchase everything normally in the kit EXCEPT the compressor. If you call them they will sell it to you this way. Then go find a competent A/C shop and they can connect the factory 5.3 compressor to the Vintage Air components.
Actually I typed that in the wrong order. Find the competent AC shop first, tell them what you want to do, then confirm what parts you should buy from Vintage Air and what parts they will want to build (fittings, hoses, etc). In my opinion that is by far the best and easiest solution.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
