Old 05-14-2012, 11:16 AM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
Angle ????
I am putting in a 5.3 with a 4L60E trans in an '82 truck. We have raised the front crossmember and are doing other mods for better handling. We plan on doing custom mounts and setting the engine back some for better weight distribution.
With the frame level, what angle should the engine/trans be installed at? I currently have it a 4 degrees (tailshaft pointing down). I would like to get the motor lower, but the oil pan would need to be changed and a notch cut in the crossmember (which I am willing to do). The trans pan is about 1/4" above the bottom of the frame. I do not want anything hanging below the frame. Is the 4 degrees good or should I go flatter to say 2 degrees?
Thanks guys,
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-14-2012, 12:39 PM   #2
jfortvalley
Re: Angle ????
i usually just make the trans level at the pan
jfortvalley is offline   Reply With Quote
Old 05-14-2012, 12:56 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Angle ????
4* is the approx recommended angle to install these engines. Mine sits roughly at 4*, which puts the pan on a slight downward slope going back. At its lowest its within a 1/4" of the crossmember.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-14-2012, 09:24 PM   #4
TR65
TR65's Avatar
Re: Angle ????
ditto. 4 degrees high in front.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 05-14-2012, 09:49 PM   #5
mighty_mike015
Re: Angle ????
Should be at the same angle as your pinion shaft at ride height.
mighty_mike015 is offline   Reply With Quote
Old 05-14-2012, 11:26 PM   #6
aggie91
aggie91's Avatar
Re: Angle ????
Thanks, that is what I was thinking.
I will set the pinion so that it will be in line while underload.
Karl
The LST Challenge:
Old 05-15-2012, 10:26 PM   #7
TR65
TR65's Avatar
Re: Angle ????
Just to be clear. The engine angle and pinion angle should be parallel but not inline with each other. Here is the Dana Spicer rules for u-joints. Making the two angles parallel guarantees rule 2 is okay. Rule 1 is so the needles in the bearings have to rotate some.
TR
1965 C10 SWB Fleet
Two owner
Old 10-29-2012, 03:48 PM   #8
Dads Burb
Re: Angle ????
This is an old post, but I need some information. I am putting a 5.3 into a 55 suburban. I know the engine should be 1-5 degrees sloped to the rear with 3 degrees the recommended angle. My question is; is that measured with the frame level or as the truck sets?
Dads Burb is offline   Reply With Quote
Old 10-29-2012, 04:17 PM   #9
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Angle ????
as it is under load...
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
5.3, angle, mounts
