10-31-2012, 02:40 AM | #301 |
Still plays with trucks
Re: Project#1: Bright Horizons - 68 Swb big block on Air!
Nice work on the roof. I was considering doing the job the same way but my only donor roof is from a small window 67 and this needs to be done to my 69 cab.
It needs both inner & outer skins due to roof mounted service light damage and leaks so I started looking at the way the factory put the cabs together. I'm looking at drilling out the spot welds on the inner panels to get them out then install the good upper inner skin onto the large back window lower inner section. Same process for the outer roof skin then reinstall the inner surface assembly. From the way the parts are assembled I think this is the way the body plant put them together so it should work out OK.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
10-31-2012, 02:34 PM | #302 |
68TT you can even pput in the small window doing it that way
11-03-2012, 11:17 PM | #303 |
VA72C10
Sounds like you have a plan!
Should get the top finished welded this week pending weather. The shop was closed last week as the owner was at SEMA so I couldn't work on the truck....plus, the weather was horrible for the first half of the week anyways...
Looking for a 67-72 swb or blazer project in or around VA. |
11-07-2012, 07:22 PM | #304 |
VA72C10
got the carb in today. Edelbrock 750 w/ electric choke....should be just right for the big block
11-07-2012, 07:37 PM | #305 |
VA72C10
It's a fresh remanufactured one from edelbrock. Hoping it's ready to run right out of the box but I do have a tuning kit if needed....have a lot of accessories for it also...
Posted via Mobile Device Posted via Mobile Device
11-07-2012, 08:33 PM | #306 |
Oh heck yeah a 750 will give that big block some pep.
Are you putting a performance Cam in it also? |
11-08-2012, 10:55 PM | #307 |
Can't wait to see how yours comes along. It will be cool to have 2 accuair C10's in Midlo!! Mine is registered and should hit the road in a few weeks. I like the blue you are going with. I haven't read the entire thread but I think this body style looks great with a shortened rear end and super deep rear wheels 10-12" wide. If you going to lay it down low might as well get some hardcore wheels.
11-09-2012, 10:03 PM | #308 |
nice 2 c some progress
11-14-2012, 09:50 PM | #309 |
VA72C10
Got the roof almost finished but darkness set in. Found some other spots lower on the driprail to patch so I took care of those as well. It's now solidly welded and ready for me to transport back to my house. I will do the frame work/suspension/air ride/brakes there and get it running and driving. Then will put all the new sheetmetal on and drive it back to the body shop for final fitment and body work and then paint.
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 11-14-2012 at 10:27 PM. |
11-14-2012, 09:52 PM | #310 |
VA72C10
Also got the mar-k molding in today!
11-14-2012, 10:22 PM | #311 |
Sweet bro!
-Rus |
11-14-2012, 11:56 PM | #312 |
I'm dyin from withdrawl over here! <twitch> |
11-15-2012, 12:29 AM | #313 | ||
VA72C10
Thanks, progress will be better once I have it home...been a mixed blessing at the shop....great access to tools and free storage are awesome...but the distance from home and lack of access and no work in the rain really hurts progress.... Thanks! In a few...
11-15-2012, 12:55 AM | #314 |
VA72C10
Pics
11-15-2012, 12:56 AM | #315 |
VA72C10
Still needs some more grinding but it's getting there, solid, and rust is gone
11-15-2012, 01:16 AM | #316 |
Nice work, you gonna run stock suspension with bags in place of coils?
Posted via Mobile Device |
11-15-2012, 01:58 AM | #317 | |
VA72C10
Yes, bags will mount on the trailing arms in place of the coil springs at the rear and on cups in the lower control arms in the front. I'll be adding 2" blocks in the rear and 2 1/2" drop spindles in the front also. And a c-notch, super trac bar, shock relocators, sway bars, new shocks, new tie rods, ball joints, etc...
11-15-2012, 11:55 AM | #318 |
Awesome I will deffineltly be following your build. You think you'll be able to air out without your diff hitting the bed? I'm also planning a big block in my 67 so I'm gonna gave to pay attention
[size=1][i]Posted via Mobile Device[/ |
11-15-2012, 04:36 PM | #319 | |
VA72C10
11-15-2012, 06:19 PM | #320 |
Nice keep us updated. I'm clods to scrapin my coils and putting bags in place I just don't want to have to cut into my bed floor. I'm runnin 4.5/7 static drop now but I just can't get bags out of my head
11-18-2012, 10:36 PM | #321 |
VA72C10
The Mar-K moldings are very nicely packaged and look nice and the clips look a lot better than the others I have seen....and they're Made in the USA!
11-18-2012, 10:51 PM | #322 |
VA72C10
11-19-2012, 01:07 AM | #323 |
Those are sweet!!!! what these set you back??
11-19-2012, 10:02 AM | #324 |
Nice trim!! I've heard nothing but good about mar-k trim. Love the 67-68 full trim!! Keep up the good work. Dustin
11-19-2012, 01:45 PM | #325 |
PROJECT 7DEUCE
Damn that trim does look nice...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
