11-03-2012, 08:48 PM | #1426 |
Re: What Did You Do With Your Truck Today ?
Read thru the TF one piece thread, watched the videos, took notes and modified my doors. I elected to keep the latch piece where it is and compenstated on the other side. So far looking good, tomorrow going to put in the regulator and masonite "glass" to fine tune it.
11-05-2012, 12:19 AM | #1427 |
Wanted to get the rear speakers off the floor, so I cut the box down so that it would fit in the cab corners.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
11-05-2012, 03:09 PM | #1428 |
Still finetuning the windows, on hold until the channels get here. Made a support for my floor jack to hold the doors during hinge installation.
11-05-2012, 05:35 PM | #1429 |
nice work
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
11-07-2012, 09:19 PM | #1430 |
Finished up my new transmission cross member. and got a quart of rust bullet.
11-08-2012, 03:48 PM | #1431 |
Pulled the seat in the Apache and tore it down to the springs, rebuilding the foam and installing a new fitted cover.
11-08-2012, 11:49 PM | #1432 |
the brown truck brought my front control arm bushings
11-09-2012, 11:10 AM | #1433 |
FINALLY got the Lokar parking brake the way I wanted it and got the boot to fit without interference from the mounting bolts. I also fabbed up a (I think) pretty sweet shifter for the overdrive unit so I won't have to use that ugly cable and big red knob under the dash.(US Gear V2, not Gearvendors) I'll get the shifter handle chromed to match the other two, but I think it turned out kinda neat. I wanted the E brake handle to stick up some cuz I think it gives a little bit of the "old truck" look.
11-09-2012, 05:58 PM | #1434 |
Looking good!
Renegade |
11-09-2012, 11:53 PM | #1435 |
Happy Days...got my wheel spacers so I can use the stock wheels with disc brakes. Now to get all the Halloween items that are drying on the truck off so I can install these shiny pieces of metal.
11-10-2012, 01:16 PM | #1436 |
sweet!!!
11-10-2012, 03:58 PM | #1437 |
Finished up the wiring. So I threw the seat back in and took it for a drive.
11-10-2012, 04:23 PM | #1438 |
put points plugs cap rotor
11-10-2012, 04:47 PM | #1439 | |
11-10-2012, 07:48 PM | #1440 |
drove mine
good looking parking brake speedbump i may need to add one to my truck this winter
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-10-2012, 10:28 PM | #1441 |
ac condensate drain line and started fitting doors.
Posted via Mobile Device Posted via Mobile Device
11-10-2012, 10:35 PM | #1442 |
I pulled it out of the garage for first time in about three months. Then it started snow. So i fiqured what the hell, went back into the garage and made a martini and watched some football.
Posted via Mobile Device |
11-10-2012, 11:03 PM | #1443 |
got the adapters and the stock wheels on.
11-11-2012, 12:09 AM | #1444 |
meter swinger
i hope it was very dry where you are ! (i mean the martini) |
11-11-2012, 01:23 AM | #1445 |
11-11-2012, 08:09 AM | #1446 |
Rear fenders got painted.
11-11-2012, 09:55 AM | #1447 |
That's a pretty fender! Dan, I've grumped about Lokar boot fit before but my limited ability has yet to figure out how to mount that brake(I've used 2) in a way that the mounting bolts or nuts don't interfere with what I consider proper mounting of the boot trim ring. I made the valence or standoff in order to have the trim ring screw down flat with 10-24 nutserts(I hate sheet metal screws) and lay flat with the carpet and still be able to remove the brake assembly if needed. Had to do the same thing with the floor mounted shifter. Maybe I'm just too picky but if they made those boot/ trim rings an inch wider on both, the problem would be solved, IMO. I got the angle I wanted by mounting the front of the brake down to the floor and the rear up through the bottom of the floor. Then I had to fabricate a new link for the cables out of 1x3 tubing since the Lokar link isn't wide enough to clear the bolt the mounting ears attach with. A simple redesign would make that brake infinitely more versitile. Close up pics if you want or need.
11-11-2012, 11:51 AM | #1448 |
[quote=_Ogre;5695722]drove mine
Show off |
11-11-2012, 10:41 PM | #1449 |
Set bed on chassis...........still gotta paint the back of cab, 4 fenders and da hood. The backyard booth is too cold now.........
11-11-2012, 11:07 PM | #1450 |
lookin good!
