Old 11-05-2012, 12:08 AM   #1
82ccshorty
82ccshorty's Avatar
Looking for a suburban
I'm about to start the hunt for a 3/4 4x4 suburban is their anything I need to look out for when looking at one? I'm going to be lifting it(a lot) I plan on putting 53inch Michelin XZLs under it.
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 11-05-2012, 10:45 AM   #2
82ccshorty
82ccshorty's Avatar
Re: Looking for a suburban
Another question. are the spring for a 3/4 truck the same as a 3/4 suburban?
Old 11-06-2012, 05:22 AM   #3
YoungBurb88
YoungBurb88's Avatar
If you'll be doing much off-road driving with it you might consider putting 1-ton shocks on it as they'll handle the abuse better.
"I just don't think my Suburban
Has much to do with climate change, oh woah,
Has much to do with climate change and my mind you cannot change..."
Tim Hawkins - Free Bird Parody
YoungBurb88 is offline   Reply With Quote
Old 11-07-2012, 03:55 PM   #4
KrazyRay
KrazyRay's Avatar
I just brought home a 73 Suburban 3/4 ton 4wd that has zero rust and is almost cherry. I'm probably be posting it for sale.
KrazyRay is offline   Reply With Quote
Old 11-07-2012, 09:24 PM   #5
zaccaglin
zaccaglin's Avatar
Noce find! Wish I could find something like that down here in Yuba.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 11-07-2012, 11:49 PM   #6
KrazyRay
KrazyRay's Avatar
Its not too often I run across something this clean.
Old 11-12-2012, 04:37 AM   #7
Jsfucttruck
They use the same springs from 73-87 in pick-up that go into the 73-91 Subs/Blazers
There are two different length springs for the rear of 3/4 ton trucks/burbs. I think before 1978 they are all 52" the later option is 56" make sure to check.
1 ton shocks?
Jsfucttruck is offline   Reply With Quote
Old 11-17-2012, 01:36 AM   #8
carney93
carney93's Avatar
1 ton shocks?
wouldn't the 3/4 ton sub leaves be stronger than the 3/4 ton truck leaves since the back of the burbs are heavier???
Money<Time+Trucks
carney93 is offline   Reply With Quote
Old 11-17-2012, 01:59 AM   #9
rcbildr
rcbildr's Avatar
Maybe when they are new, but burbs have more weight over the back end which cause the springs to flatten/weaken out over time. A lot of the half ton Burbs have this problem and some of the really hammered 3/4tons I've seen look like they are draggin a little in the back.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 11-17-2012, 08:10 AM   #10
gmachinz
I would suggest whatever year you get and this works for.trucks too, grab the underfender splashguards from an 88-91 suburban-it helps keep dirt/debris from building up and rotting out the cab floor support gussets. It's a small tip but it'll save your sheetmetal!
gmachinz is offline   Reply With Quote
