10-23-2012, 11:00 PM | #1326 |
Re: Kabwe's aka Bam's build
That chrome and paint are magical together.
10-23-2012, 11:03 PM | #1327 |
Certified Car Nut
10-24-2012, 11:20 AM | #1328 |
Kabwe, you are a true craftsman ! You have done some outstanding work on this project. I am wondering if you have done or seen someone do a 55-57 hood modification using part of a 58-59 hood. As in cutting the area with lines on the 58-59 and putting that top area on the 55-57. just wondering if its been done. You do good work!
10-24-2012, 11:40 AM | #1329 |
I usually go chromabase and Nason clear, works great. Color looks good!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
10-24-2012, 11:55 AM | #1330 | ||
Certified Car Nut
Checkout out jjjmm56 build thread. He made fabracations to his 56 Chevy hood to make it look like a 58-59. Here is a link to his build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=350951 Quote:
Yeah I was pleasantly shocked by how well this Nason clear laid down. No yellow hue and like glass. I'm just a glorified shadetree type guy so it works for me. Last edited by Kabwe; 10-30-2012 at 08:04 PM. |
10-24-2012, 02:17 PM | #1331 |
10-24-2012, 09:07 PM | #1332 |
Bam,
Someone over on the HAMB board referred to you having taken off your roof to address rust around the perimeter between the inner and outer skins. Did you do this? If so, I went backcthrough this thread and didn't see it. I am wondering if that work was not replaced when you lost your photos and had to re-post? If so, any chance you could post some photos (if you have them) and explain what's involved? I have literally one inch of rust-through right where the passenger side gutter meets the roof skin - small, but I know there's more in there. I also have what I think is some old rust through inside that an old owner did some bad gas welding on in an attempt to just "cover the holes". This part is a guess but I THINK that's what happened. I HAD planned to flap disc the interior weld blobs, MIG the exterior rust-through, reseal the gutter with modern sealant, and coat in between the skins with a heavy double coat of the Eastwood internal frame rust preventative stuff - mostly cause I don't have your fab chops or the money to pay others to do it!! Tell me how difficult the de-roof/re-roof is and your thoughts on my plan? Be honest, I can take it. |
10-25-2012, 06:36 PM | #1333 |
Is there some green paint in your 55's future?
10-25-2012, 06:46 PM | #1334 |
What metal polish do you use? That wheel looks out of sight...Mothers in the can just hasn't done that for me and I been using it 20 years now. Thanks in advance!
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
10-25-2012, 11:04 PM | #1335 |
Looks Killa Kabwe. the flake makes it pop, should look good over a large surface in the sun, and with a truck with so many curves on it.
Blake. Sydney Aus 56 Chev 3100 build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363 LOW n LOUD |
10-26-2012, 02:13 PM | #1336 | |
Grand PooBaa Member
Except the interior? Wait what are you saying, the great, mighty and all powerful BAM, is not doing his interior? Say it aint so! As for helping you, you know darn well your not going to call us cause we might accidentally pick up a tool and try to turn a bolt, and if it does not line up, your going to have blood on your hands. LOL!!!! Yes im causing trouble again. That color next to the wheels, thats a killer combo. |
10-26-2012, 02:45 PM | #1337 | |
Certified Car Nut
I fixed that roof two times.lol So I don't know which one you are talking about so I will post pics of both. The first fix was when I just fixed the rust under the eye brown. I did that before I found out that they sold new roof panels. First fix pics Rusted area Cut out the rust Handmade patch panel Welded it in and grind and primed. Second fix I found out they sold new roof panels so I purchased one. As you can see in the pic, the new roof has the area under the eye brow the is a rusted area on a lot of our trucks. It also comes with the drip rails. This is the part of the drip rails the ride on top of the cab's rails like a sandwich. I'm not running drip rails so I cut them off. After a lot of measure I cut the roof of my cab. The eye brow section is spot welded on. If you are keeping the drip rails clean the area good and you well see the spot welds there also. Completed Roof |
10-26-2012, 02:52 PM | #1338 | |||
Certified Car Nut
Yep
10-26-2012, 03:47 PM | #1339 |
Grand PooBaa Member
10-26-2012, 11:36 PM | #1340 |
Thanks for the info Bam.
I've got a lot of stupid questions about this but let me ask the most basic: If I find those spot welds and use a spot weld cutter...is it then just a matter of carefully prying the roof panel to separate it from the cab? If so, once I'd repair any damage to the cab part, does the roof panel just drop into place (relatively) for plug welding? I see surface rust on yours, did you use some kind of coating or weld-thru primer in there before replacing your roof? Any other details about how relatively difficult/easy it is to do this repair? |
10-29-2012, 11:51 AM | #1341 | |
Certified Car Nut
Dan start with the spot weld first and that will guide you to what you may have to cut. There are also spot welds along the bottom ridge of windshield panel. Yes I did wire brush the inner roof panel and coat it with zero rust primer. Difficulty. I really don't find anything difficult just a lot of work and very time consuming. If you can weld, cut, and measure you can do this. It would not be my first project do some other rust repair until you build your confidence up and you will be able to do this no problem. Its about being confident man and you have half the job done. Last edited by Kabwe; 10-30-2012 at 07:45 PM. |
10-29-2012, 01:13 PM | #1342 |
If you try this, get a spot weld cutter. Not real expensive and makes a lot of the sheet metal stuff on these old trucks a breeze. A knotted wire brush run down the channel will show the spots, centerpunch in the middle of the spot and drill them dudes!
11-04-2012, 08:32 PM | #1343 |
Certified Car Nut
Well I got a little more done today. Slowly I turn, step by step, inch by inch.lol Well thats how I doing it.
I know its over kill by I base coat cleared the gas tank just because. No other reason. Here is the tank installed between the frame rails. |
11-04-2012, 08:39 PM | #1344 |
Tank looks super between the rails, nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-05-2012, 12:34 AM | #1345 | |
Grand PooBaa Member
Great work Bam, that tank looks good. But we would not expect anything less from you. |
11-05-2012, 01:58 AM | #1346 |
Looks good.
Kim |
11-05-2012, 09:59 AM | #1347 |
No such thing as over kill , that's just normal in a car guys world.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-05-2012, 12:34 PM | #1348 | |
Certified Car Nut
Thanks guys
11-05-2012, 07:42 PM | #1349 | |
not many people think this way tank install looks good too
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-05-2012, 08:21 PM | #1350 | |
Certified Car Nut
I did not mean it in an arrogant way at all. I just believe that we are all human beings and can learn these skills. But after you learn the skills and you will if you keep at it. It still will be a lot of hard work. That is the one thing that will never change no matter how much your skills improve.lol |
