Old 11-05-2012, 07:28 PM   #1
savatreatabvr
savatreatabvr's Avatar
SquareBore to Spreadbore Adaptor Plate! (Is it Necessary?)
As you all know I have my share of issues with my mid 70's 454 so when I came across an almost new Edelbrock Performer 1407 carb for a great price I bought it on the spot! Of course I didn't flip it over to see if it was a spreadbore until the next day and of course it's not! Can I bolt a squarebore carb to a spreadbore intake without an adaptor and make it run right?
savatreatabvr is offline   Reply With Quote
Old 11-05-2012, 08:00 PM   #2
GM-power
GM-power's Avatar
Re: SquareBore to Spreadbore Adaptor Plate! (Is it Necessary?)
Without an adapter or squarebore intake it wont run right. I know people who don't even like the adapter ideas. I hope this answers your question.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 11-05-2012, 08:10 PM   #3
frog210
you have a aftermarket intake?
i bolted my eddy 1806 i think 650 cfm to a performer 2101 intake
it worked fine for me
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 11-05-2012, 08:11 PM   #4
MalibuSSwagon
I had an adapter on mine, I wouldn't recommend it, best bet would be a matching intake manifold.
MalibuSSwagon is offline   Reply With Quote
Old 11-05-2012, 08:19 PM   #5
savatreatabvr
I used an adaptor on my 440 Moho and it worked great! As far as I know the only difference is the size of the back two barrels, right?
Old 11-05-2012, 08:35 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
Just buy the adaptor
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-05-2012, 08:35 PM   #7
Keith Seymore
Keith Seymore's Avatar
Right.
I'm not morally opposed to a carb/intake adaptor.
I hop back and forth between a Dominator (for unlimited use) and a square flange Holley (for nostalgia classes) by using a Wilson adaptor.
My engine makes about 950 hp, car goes 9.80s at 3950 lbs.
Seems to work ok -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-05-2012, 08:57 PM   #8
savatreatabvr
My application is more for street use, lol but I'll take ya'lls advice and buy an adaptor!
Originally Posted by Keith Seymore View Post
Right.
Seems to work ok -
K
Old 11-05-2012, 10:31 PM   #9
INSIDIOUS '86
INSIDIOUS '86's Avatar
An aftermarket intake would be a great way to wake up your truck beaver. I lil more money and time involved but shaving 50lbs and making more power is never a bad idea.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-06-2012, 07:30 AM   #10
bigd65
bigd65's Avatar
If you believe in the fuel velocity thing, you need to put the spacer on. With out it, can disrupt air flow because the walls won't be smooth all the way down the venturi's. I say that because some people don't believe in the air flow velocity thing even with a regular spacer on say a fuel injection and such. I do, I think the walls inside of the venturi's need to be smooth to keep the even fuel velocity
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 11-06-2012, 11:54 AM   #11
INSIDIOUS '86
That is with a normal spacer. This adapter actually kills velocity and creates turbulence and not in a good way
Old 11-06-2012, 02:12 PM   #12
88Jimmy4x4
88Jimmy4x4's Avatar
I have heard you say this a couple times, do you have any proof or dyno sheets to back this up?....just curious
1991 GMC Jimmy 4x4
Old 11-06-2012, 07:34 PM   #13
savatreatabvr
I kinda believes it all needs to be smooth but proof is best!
Old 11-06-2012, 10:20 PM   #14
INSIDIOUS '86
I had a carb spacer test saved on my computer but the computer is no longer... And I can't find the article again. But take a look and tell me how bending the air almost 80* right as it exits the carb isn't going to be detrimental?
Old 11-06-2012, 11:34 PM   #15
savatreatabvr
This is the Mr. Gasket Squarebore to Spreadbore intake manifold adapter I was talking about! It only makes sense to me if it's installed upside down! I think I need your's INCIDIOUS '86!
Old 11-07-2012, 08:10 AM   #16
88Jimmy4x4
88Jimmy4x4's Avatar
never seen one like that, Im referring to the all open adaptor spacer, dont see how that can be as bad as you make it out to be.
1991 GMC Jimmy 4x4
Old 11-07-2012, 08:13 AM   #17
BigBlocksRule
savatreatabvr, (didn't get that until I tried to say it!), I think I have one of the open Q-jet to square bore adapters, it's yours for shipping if you want to give it a try.
BigBlocksRule is offline   Reply With Quote
Old 11-07-2012, 08:14 PM   #18
88Jimmy4x4
88Jimmy4x4's Avatar
who makes that?....ones I see on summitracing and jegs are open plate designs so there is no "bending" of the air as you claim that one has.
1991 GMC Jimmy 4x4
Old 11-07-2012, 08:29 PM   #19
savatreatabvr
Mr. Gasket from Checker Auto Parts!
Old 11-07-2012, 08:31 PM   #20
savatreatabvr
I'll try anything at this point!
Old 11-07-2012, 09:00 PM   #21
savatreatabvr
Like I said in my first post, is a Squarebore to Spreadbore adapter necessary? I do believe bolting a Squarebore carb to a Spreadbore intake can disrupt the air flow and hurt performance but I'm not running a 9 second car, I'm driving an old high mileage big block! I'm going to bolt it on and see what happens, I'll keep you all posted!
Old 11-07-2012, 09:30 PM   #22
i8tokyo
Is it a stock, cast-iron intake? If so, you'll need the adapter. Since it's an edelbrock carb you really should use the ported style adapter. Edelbrocks PN is 2696.
1982 C-20, 454, TH-400, PS, A/C, 71,000 miles
1978 C-20, 350, TH-400, PS, Non-A/C, 112,000 miles
If it ain't broke, there is still probably room for improvement.
Speed costs money, how fast do you want to go?
i8tokyo is offline   Reply With Quote
Old 11-07-2012, 10:25 PM   #23
savatreatabvr
Yes it's stock and yes I know I need the #2696 but here's what I was told about the 2696! Lopers, (a High Performance Shop here in Phx) said the Edelbrock 2696 Squarebore to Spreadbore adapters have a tendency to crack and cause minor to severe vacuum leaks! I didn't know if I should believe him or punch him, lol, so I walked away empty handed! Ya know a big block aluminum squarebore intake manifold doesn't sound like a bad idea now, Lol!
Old 11-07-2012, 10:40 PM   #24
INSIDIOUS '86
The spacer is there to make sure that the gaskets seal correctly. And the bolt pattern matches between carbs
Old 11-07-2012, 11:47 PM   #25
savatreatabvr
