11-06-2012, 11:31 AM | #76 |
Re: Hood & fender emblems
One cool fire truck there. I light the high mount spotlights. And thanks for sharing the emblem
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-29-2013, 10:50 PM | #77 |
Does anyone know if a 66 Custom Camper will interchange with a 66 C20 emblem? Are the holes the same?
04-29-2013, 11:17 PM | #78 |
05-27-2013, 01:34 PM | #79 |
Hello, I bought a 1964 C-10 Custom Suburban, and it has 3 holes on the side of the hood near the front tires, its a 3 hole triangular pattern and I can't seem to find an emblem that goes there, thinking the hood may be off of a GMC, but the V6 emblems I see only have 1 prong, not 3? Anybody have a similar hood?
05-27-2013, 04:26 PM | #80 |
Which year would these be from? I also have a set like this minus the "Magnum" script and lightning bolts.
MusicMan70 1961 GMC Suburban |
05-29-2013, 12:30 PM | #81 | |
Registered Loser
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
05-29-2013, 09:29 PM | #82 |
are the holes on both sides or just one? might have been a turn signal mount. i have seen them installed on the hoods and fender extensions
06-01-2013, 12:09 PM | #83 |
nope, holes on both sides,
Also, turn signals are rectangle....looking at the web pics, looks like GMC's turn up, I see what your getting at, can't be a GMC hood, I learn something everyday on this site! Thanks... |
06-01-2013, 03:25 PM | #84 | |
1961 crewcab
here is some info: The 477.7-cubic-inch (7,828 cc) 478 was one of the largest V6 engines ever built. Gross output was 235 hp (175 kW) at 3200 rpm and 440 lb·ft (597 Nm) at 1400 rpm. Bore was 5.125 in (130.2 mm) and stroke was 3.86 in (98 mm). It was introduced in 1963 in the 6500 series trucks. It was superseded by the 1966 478M "Magnum" series, and production ended by 1974. Gross output was now 254 hp (189 kW) at 3700 rpm and 442 lb·ft (599 Nm) at 1400 rpm. also: http://www.6066gmcguy.org/Jolly-401v6.htm
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-13-2013, 01:57 PM | #85 |
Ok, have a new addition. The 1960 & 61 hood jets (ornaments). Here are a few pics from different threads and a few from one that I just got. The shorter nose is the GMC and the longer nose is the Chevy version
06-13-2013, 01:59 PM | #86 |
Heres a few more and a pic of where i've mocked up to install. If someone has a nice installed pic of a GMC hood jet, please post the pic for us.
06-13-2013, 02:25 PM | #87 |
It's Better With Nitro
Here's a thread I started a few years back regarding an emblem I milled that was based on the Apache 10 script from the 1960 hood emblem.
http://67-72chevytrucks.com/vboard/s...d.php?t=354378
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-13-2013, 02:37 PM | #88 |
very cool, we'll have to post a pic of it here
06-13-2013, 02:46 PM | #89 |
08-14-2013, 11:27 AM | #90 |
Any new additions?
08-14-2013, 06:05 PM | #91 |
I wonder how hard the "Diesel" badges on the hood are to find?
08-14-2013, 09:10 PM | #92 |
ive never seen one personally. may also be an item they used for advertising or concept that never made production. now the search begins to see if anyone has a pic or has ever seen one in person. very cool though.
08-14-2013, 10:48 PM | #93 |
The 3 guys in the picture are smiling waaaaay too much for that same picture to be used in any advertising these days.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
08-15-2013, 12:00 AM | #94 |
08-15-2013, 06:59 AM | #95 |
My 64 C10 has perfectly aligned holes on left and right side cowling(s) but I have yet to come across what emblem may have been there. Somewhat new to this so go easy.
1964 C10... work in progress 1971 GMC 2500 Sierra Custom Camper |
08-15-2013, 07:03 AM | #96 | |
08-15-2013, 08:18 AM | #97 |
The truck is a General Motors Argentina D-200. My Spanish isn't that good but as far as I can tell, It's a 1/2 ton short stepside, BBW with a 4 cylinder diesel. 4 speed transmission, 16" wheels and 2 batteries. The only options I see are a radio, heater and locking rear end or "steering lock" not sure. I have the brochure scanned. I can't seem to shrink it down enough to post. If anyone would like it just PM me with email address and I'll send the pdf.
08-15-2013, 08:43 AM | #98 |
Sounds to me like you have cowlings off of an earlier model that had emblems placed higher. The cowlings can be swapped from 60-66. Also there were a lot of dealers that installed dealer emblems in these locations.
08-15-2013, 11:15 AM | #99 |
I thought D-series was a dodge designation even in the foreign trucks.
08-15-2013, 02:19 PM | #100 | |
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
