Old 11-06-2012, 10:48 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
How To - 3/4 Ton - Converting to a 14bolt
CaptainFab has been making these for the larger diameter axles such as the 14-Bolt used in Gm 3/4+ Ton Trucks from 1973 to 1987?
Captain will know more specifics.
Either way, I have been asked by several members how I went about converting my 66 3/4 to a 14-Bolt.
CaptainFab's Perches/Seats/Saddles
I layout much of the 'How To' in my 66 Build Thread, but I figured I'd make a dedicated thread where others could ask questions and share experiences.
So, I'll layout how I did mine.
14-Bolt Ready to grind off Leaf Spring Perch's:
Leaf Perch's and Shock Mounts ground off:
Here is CaptainFab's Trailing Arm Perch - Fits Perfect:
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-06-2012, 10:48 PM   #2
LostMy65
LostMy65's Avatar
Re: How To - 3/4 Ton - Converting to a 14bolt
I don't want to be doing this from under the truck, so I set-up kind of a jig to line everything on the Eaton up.
I nailed 2x6's to my shop floor so they won't budge.
You could nail yours to a piece of Plywood.
I traced the Eaton's Trailing arm perches U-Bolt holes.
Then I will use this for getting CaptainFab's new Perches lined up on Corp 14-Bolt to match the Eaton perch location.
Old 11-06-2012, 10:49 PM   #3
LostMy65
LostMy65's Avatar
I scribed and cut a piece of scrap particle board at the angle that I will need for setting the 14-Bolt at the same angle as the Eaton.
Old 11-06-2012, 10:49 PM   #4
LostMy65
LostMy65's Avatar
I got Captainfab's Perches tacked.
Pinion angle is set the same as it was on the Eaton.
Old 11-06-2012, 10:50 PM   #5
LostMy65
LostMy65's Avatar
I got the u-bolts made and bolted them up the 14-bolt to the trailing arms.
For the panhard bar, I cut the bracket off the Eaton and welded it to the 14-bolt.
Old 11-06-2012, 10:53 PM   #6
LostMy65
LostMy65's Avatar
Old 11-07-2012, 01:58 AM   #7
Captainfab
60-66 Nut
Thank you for starting this thread Robert
I'm sure this will help those that are considering converting to the 14 bolt for the advantages of better gearing and better parts availibility.
One question. Did you have to shorten the driveshaft, and/or did you need a different rear U-joint?
Old 11-07-2012, 02:01 AM   #8
LostMy65
LostMy65's Avatar
I did not need to shorten the driveshaft.
I did not need a different U-Joint.
I bought new U-Joints, but they were the same size as I had with the eaton.
Old 11-07-2012, 04:35 AM   #9
gmcdeadhead
gmcdeadhead's Avatar
i'm gonna order a set of perches from captain fab and do my conversion over the winter . does anybody no where i can get some drum brake backing plates from for the 14 bolt?
gmcdeadhead is offline   Reply With Quote
Old 11-07-2012, 05:25 AM   #10
cp_66_c20
cp_66_c20's Avatar
Is the dually Dana 80 a good reared to use for a conversion? I was looking at it for the gross weight it can handle. I know that it will take some fab work witch i understand. If not then i will go for the 14 bolt Dana 70. Witch brings me to another question. Can you weld on the 60 to 66 frame? I was told and heard that it was heat treated and that it would make the frame weaker. Thanks for any info and the write up answered some questions i have had.
cp_66_c20 is offline   Reply With Quote
Old 11-08-2012, 01:04 AM   #11
Captainfab
60-66 Nut
What is the diameter of the drums on yours. There are 2 different sizes of drume, and hence the backing plates. What is wrong with yours?
IMO, unless you are building a C30 for doing some serious hauling, the Dana 80 is a bit overkill. The 14 bolt, or a Dana 60 or 70 would be fine for a C20. To my knowledge the frames are not heat treated. Although they are typically an alloy of steel that is tougher than mild steel and will flex more without fatigue. You just need to be an experienced welder to correctly weld on a frame. Otherwise you could have a catastrophic failure.
Old 11-08-2012, 04:11 AM   #12
cp_66_c20
cp_66_c20's Avatar
Yea that's what i was wanting to build it for. I plan on hauling cars, trucks, maybe a tractor or two, and some other things. I have some experience welding but i am not and expert yet. The reason i was asking is cause i don't want to put the time and money into it. Then accidentally bend frame from a week spot or something more catastrophic like you were saying. Thanks for the wealth of knowledge and the help.
Old 11-11-2012, 06:42 PM   #13
gmcdeadhead
lost my 65, that receipt you have showing the u bolts that were made up , is that the right size and dimensions i should go get made up to do my 14 bolt conversion? thanks
Old 11-11-2012, 11:17 PM   #14
pope
pope's Avatar
Made the same swap in my 4x4, sure is nice to have some taller gears!
Where the hell did my coffee cup go?!!
pope is offline   Reply With Quote
Old 07-13-2013, 05:07 PM   #15
jtrichard
what did you have to do with the u-bolt spacing on the trailing arms?
jtrichard is offline   Reply With Quote
Old 07-13-2013, 06:26 PM   #16
gmcdeadhead
i did the 14 bolt conversion on my 1966 c-20 already. i got a whole chassis from a 1987 1 ton chevy truck and used the 14 bolt for the conversion.(i will be doing the front end conversion also from the chassis i bought), i had to get my drive shaft cut by
1-1/2 inch, i have a 292 with 4-speed in it. i bought standard u-joints and bought a new carrier bearing. the rear brake cable on the left side i had to modify to get it to work , the right side worked ok. the dimensions for the u-bolts work out great , went into the trailing arms with no problem. capt fabs perches worked very well also, any other questions feel free to ask.
Old 07-13-2013, 09:40 PM   #17
jtrichard
was the 1 ton a C&C? drw? i found a C&C that i sold 8 years ago now getting it back for $100 it is the same width +/- 1/2" as the eaton i have a 82 donor truck with 6.2 diesel and good front suspension and good rear 14 but i did not fight the 3to4" wider ....i have not checked the yolk to center on both axles but you said you had to shorten the shaft and lost 65 said he did not???
Old 07-13-2013, 10:04 PM   #18
LostMy65
LostMy65's Avatar
I had enough depth still available in my slip yoke that I didn't need to shorten my shaft.
gmcdeadhead may have needed to shorten his so his slip yoke wouldn't bottom out.
Old 07-14-2013, 04:15 AM   #19
gmcdeadhead
yep , i had to shorten so slip yoke would not bottom out.
Old 08-29-2014, 01:53 PM   #20
LostMy65
LostMy65's Avatar
For some reason I didn't remember I made this thread. Someone was asking about it.
Old 08-29-2014, 02:46 PM   #21
Woogeroo
Exclamation Re: How To - 3/4 Ton - Converting to a 14bolt
This thread was added to the Driveline category of the Engine & Drivetrain section of your 60-66 FAQ Index.
Thanks for sharing.
-W
NOTE : if this link changes in the future, look for the sticky at the top of the 1960-66 Message Board.
Woogeroo is offline   Reply With Quote
Old 08-29-2014, 08:26 PM   #22
earl84
This thread helped me immensely when I put a 14 bolt in my C20. Thanks for doing it, and thanks Woogeroo for your FAQ work.
earl84 is offline   Reply With Quote
Old 08-29-2014, 09:10 PM   #23
LostMy65
LostMy65's Avatar
Glad it helped. Thanks.
Here is the other thread by azdeltawye that I think was inspired by mine:
http://67-72chevytrucks.com/vboard/s...d.php?t=624445
Old 09-04-2014, 03:51 PM   #24
azdeltawye
azdeltawye's Avatar
Yes, I was inspired by your thread.
I forgot to give credit where credit was due.
Thanks!
1965 C20, 350 cid, '71 front Disc brakes, NV4500 5-spd, 4.10 FF 14-bolt
azdeltawye is offline   Reply With Quote
Old 04-01-2016, 04:44 PM   #25
LostMy65
LostMy65's Avatar
I had no trouble getting the new U-Bolts through the holes in the Trailing Arms.
