Might be the owner of crew cab
Might be buying another crew cab square. 4wd 1984 silverado. Its been cOnerted nO motor/Trans everything else is their. it's a conversion company truck too so the custom interior.
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
Re: Might be the owner of crew cab
i just relized the pic didnt load
6>8 Plugless........
![]() Join Date: Sep 2007
That looks like a great truck to work with.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
I'm going to make it like your truck was on 53s
Cool deal man!
Can you give me some info on What all you had done? To get it that high
GO BIG! crews look bad-ass lifted. it looks like it already has about a 6-8" lift in it, that's pretty much how mine sits when i stuff it in the garage in the background ( i also pull the valve stems & unbolt the shop door )
It's 6 inch front 8 inch rear
#9 | |
Did you ever drive it at all?
Not with the 53's on it. I drove it before the upgrade back when it had the 396.
Cause I was talking to my buddy and he said the 53s were the worst driving tires he's ever drive he said they drive the truck not you.
I sold my tires and wheels to a local guy and he said they drove just fine. Alot of it could have been the truck/roads.
thats what i thought. what did he put the tires on?
#15 |
A 97 suburban with a SAS swap.
#16 |
im guna give them a shot if they dont work out i might just buy me some TSL boggers or some Baja Claws
#17 |
I can't find shocks anywhere. I found 22 inch lift sprigs
#18 |
find the longest shocks you can, then fab up some drop brackets off the frame. my buddy with a 15" lift (all spring) on his k20 made a long drop bracket to mount dual shocks. when your that hi with them big tires though, your tires are basically your shock asorbers
#19 |
On your truck did you have to drop the center bearing?
#20 |
I did get a chance to go look at it finally today. It's really solid truck. It has 4 wheel disc crossover steering superlift all spring lift aluminum radiator. NP205 t-case. Skyjacker shocks. It has a tach dash that comes with it also. It has bucket fronts bench rear. It was converted the right way it looks like.
#21 |
sounds like you just need to drop in a b.block, throw on some 38 or 39's & go wheeling. 14 & 60 axles?
#22 |
its a 14 & 44, i did find me a 396 for it the motor needs heads and a intake, i have a pair of steel heads still looking to see if i have a intake. got to find a Trans for cant decide if i want to put in a 700r4 or a 400. i have a 700r4 here out of my other truck and since im not making it 4x4 im not going to use the 205 in this truck im going to use it in my 80 gmc.
#23 |
ya, i've been seriously debating throwing a 700r4 in my crew. a 1:1 3rd gear with 4:56's & 38.5's behind a b.block is real detrimental to fuel mileage. i rebuilt the 400 in 08, & it's been rock solid though, just sucks going threw the mountains with the camper & trailer
#24 |
im probably going to use the 700r4 for the OD and maybe a little better mileage. Ive got my basic lift of what to order/get now to get it closer to being done but now i need to decide what im guna do for paint probably flat black with old school pin striping
#25 |
heres my basic list:
Wheels XD diesels 20x12 16.00r20 tires (53s) Front 22inch springs Rear 22inch springs Steering correction parts Big block intake Carburetor If you guys think of anything else i might need let me know
