11-07-2012, 12:58 AM | #1 |
new gas gauge still pegged full
my trucks gas gauge was pegged on full, I unhook the wire from the sending unit, still reads way past full. SO I thought the fuel gauge was bad. install new one same things happens.....
what is it sending unit wire shorted out??? |
11-07-2012, 10:29 AM | #2 |
Re: new gas gauge still pegged full
Sounds too me like it's grounded
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins Last edited by black_sheep454; 11-07-2012 at 11:45 AM. |
11-07-2012, 11:21 AM | #3 |
Trace the wire from the dash to the tank, I bet it's shorted against the body somewhere, grounding it making it read full. Look under your sill plates, one of the screws holding it down may have pierced the wire.
http://smg.photobucket.com/albums/v655/aaronhero/ |
11-07-2012, 11:45 AM | #4 |
Empty is 0 ohms=grounded;
Half is 44 ohms to ground; Full is 88 ohms to ground your sender wire is open between the gauge and sender |
11-07-2012, 12:25 PM | #5 |
You are grounded out somewhere for sure. Tracing the water is your best option, or just replace it. Grounding it out, it will read full. With unhooked it should read about a 1/3 of a tank ( I think). Simple fix.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
11-07-2012, 08:34 PM | #6 |
68K30 has the information listed correctly. Try grounding the terminal on the fuse panel where the brown wire from the tank plugs in. It should go to empty with the key on.
Also, make sure the fuse that feeds the gas guage is good. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
11-08-2012, 06:34 PM | #7 |
Good fuel guage reads about 90 ohms+- 5ohms or so unwired. Just checked. Wire from fuel sender unhooked from sender to ground should read approximatley the same, just checked also. I am checking all of this for a guy at worrk is having some problems with his. Radings may vary on temperature a bit. Hope this helps.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
11-19-2012, 09:28 PM | #8 |
Thank you for the replays...it was a big air gap.....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
