Old 11-07-2012, 02:18 PM   #1
t korinek
Truckin' Krazy
t korinek's Avatar
Drop spindles & 3" front drop springs
Not sure of brand on these parts, just came off a driving 72 suburban, it sat too low.
5 lug factory rotors & calipers & a few of the wheel studs need replaced.
For whatever reason the lower ball joints on these were the large 3/4 ton & had 3/4 ton lower a arms on it also. $125 for just the spindles + shipping
3" springs are sold
Will include the 3/4 ton a arms also if you needed them.
Thanks,
Tom
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 11-07-2012, 02:19 PM   #2
t korinek
Truckin' Krazy
t korinek's Avatar
Re: Drop spindles & 3" front drop springs
A few more pics
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
Old 11-07-2012, 05:36 PM   #3
72mistressc10
72mistressc10's Avatar
Are you willing to part out the springs for a local guy?
1972 C10 LWB Cheyenne Super
God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
........................__
..........._______ |__\__
..........|__(O)______(O)]
72mistressc10 is offline   Reply With Quote
Old 11-07-2012, 06:29 PM   #4
t korinek
Truckin' Krazy
t korinek's Avatar
72Mistressc10 I'll sell the springs for $60 picked up.
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
Old 11-07-2012, 09:52 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
How about selling the dropped spindles only?
WIDESIDE72 is offline   Reply With Quote
Old 11-07-2012, 11:11 PM   #6
t korinek
Truckin' Krazy
t korinek's Avatar
Ill sell just the spindles for $125 + shipping
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
Old 11-08-2012, 03:11 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
Any idea how much drop the spindles give, and if they will still work with 1/2 ton ball joints? How about a shipping cost to Leander TX 78641?
Old 11-08-2012, 08:27 AM   #8
J kippin
J kippin's Avatar
I will take the spindles if they will work with the stock 1/2 ton ball joints and lower control arms.
J kippin is offline   Reply With Quote
Old 11-08-2012, 08:35 AM   #9
WIDESIDE72
WIDESIDE72's Avatar
This puts me first in line for the spindles.
Old 11-08-2012, 10:46 AM   #10
J kippin
J kippin's Avatar
Hey wideside 72...didnt mean to sound like a dbag. meant to say I will take them if you dont.I think that means I would be second
John
Old 11-10-2012, 01:24 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
Old 11-10-2012, 03:00 AM   #12
t korinek
Truckin' Krazy
t korinek's Avatar
I don't know if they will work on your 1/2 ton or not, they were on a 1/2 ton 72 burb & have factory 5 lug rotors & calipers attached, but the lower control arms were 3/4 ton.
Most drop spindles are 2-2 1/2" & I would imagine that's what these are.
If you know the measurements of what you need are please post them & I will check.
I'll have to take this apart to get a guess of what the shipping will be & With any luck I'll find a part #
Thanks,
Tom
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
Old 11-10-2012, 03:17 AM   #13
WIDESIDE72
WIDESIDE72's Avatar
Thanks,
Tom
THanks TOm, I will get some measurments tomorrow. Do you know what is different about the 3/4 ton arms vs 1/2 ton?
Old 11-10-2012, 10:20 AM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
The hole for the lower balljoint is bigger in the 3/4-ton version.
IF these spindles were on a 3/4-ton balljoint,... they won't work on a 1/2-ton balljoint.
Is the upper balljoint also a 3/4-ton balljoint?
Is the outer tie rod different also?
Maybe the burb was converted to 1/2-ton.
Either the burb has conversion spindles like ECE sells, (even though I don't see their name on these),...
or someone has taken a reamer to the lower hole to allow the use of a larger 3/4 ton ball joint, on a 1/2 ton truck.
Keith
Convert to disc brakes.
Old 11-10-2012, 11:44 AM   #15
WIDESIDE72
WIDESIDE72's Avatar
It is weird that it has 1/2 ton upper joint but 3/4 ton lowers... Or are the uppers the same? I haven't checked that yet. I have found that 3/4 ton lowers are bigger (go figure!)
Old 11-10-2012, 12:02 PM   #16
lolife99
lolife99's Avatar
72 3/4-ton upper balljoints are different.
But I have no idea what these spindles are.
Does it for sure, have a 1/2 ton upper balljoint hole?
Keith
Old 11-11-2012, 12:02 AM   #17
WIDESIDE72
WIDESIDE72's Avatar
I will pass
Old 11-17-2012, 04:25 PM   #18
BMERDOC
BMERDOC's Avatar
The spindles are 88-98 spindles. They have the same size upper ball joint but you have to swap to the 3/4T lower arm to get the same ball joint the 88 and up 1/2T used. Hope this helps clear things up for you and a bump for you as well!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
