Old 11-07-2012, 09:17 PM   #1
gcottingham
gcottingham's Avatar
'69 C/20 Drum to Disc Conversion??
I have recently purchased a '69 LWB C/20 with coil spring suspension, 396, HD 4sp, and Dana 60 rear end. It has drums all around. I want to upgrade to disc brakes all around, or at least in the front.
I have not been able to find a kit for such a conversion. Does anyone have any thoughts on this project?
gcottingham is offline   Reply With Quote
Old 11-07-2012, 09:19 PM   #2
gcottingham
Re: '69 C/20 Drum to Disc Conversion??
By the way, it has 8-lug wheels on it.
Old 11-07-2012, 09:23 PM   #3
Mister-B
I think most guys just get the parts off a '72 from the junk yard, and install
Mister-B is offline   Reply With Quote
Old 11-07-2012, 09:23 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome to the board.
Look here for complete kits.
I just linked the front kit,... but they sell individual components also.
http://www.performanceonline.com/63-...-deluxe-8-lug/
Keith
Convert to disc brakes.
Old 11-07-2012, 09:25 PM   #5
lolife99
lolife99's Avatar
This is a good source for 8-lug rear disc brake kits.
http://www.blackbirdscustomtrucks.com/index7.html
Keith
Old 11-07-2012, 09:53 PM   #6
gcottingham
Thanks for the info! Would it make sense to switch to 6-lug so I can find better wheel options?
Old 11-07-2012, 11:42 PM   #7
lolife99
lolife99's Avatar
If you are going that far,... I would switch to 5-lug.
Most late model (1999-2012) 6-lug wheels (oem or aftermarket) aren't designed to fit these old trucks.
The center hub is too big for the small hole in the late model 6-lug wheels.
The 5-lug pattern is very common and there are tons of wheels available.
This will require you to do a rearend swap.
Is your truck a coil spring (rear) truck or leaf spring?
Keith
Old 11-08-2012, 02:40 PM   #8
gcottingham
It's a coil spring rear end. Dana 60 rear diff.
Old 11-08-2012, 02:45 PM   #9
lolife99
lolife99's Avatar
A 71-72 5-lug rearend will work great for your truck.
Keith
Old 11-08-2012, 02:56 PM   #10
gcottingham
I'll check into that. Thanks!!
Old 11-08-2012, 07:37 PM   #11
airdale94
airdale94's Avatar
I would just swap the front and keep the 8 lug. There are plenty of 8 lug wheel options. You can get the parts from a 73-87 C20. It will move your front wheels out about 1" though. I did this on my 68 C20. Reply if you want all the specifics.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 11-08-2012, 10:37 PM   #12
70chevytruck
I would like to know what you used for the swap...I have a 68 c20 that needs disc in the worst way! Thanks,
70chevytruck
70chevytruck is offline   Reply With Quote
Old 11-09-2012, 08:27 AM   #13
bopper_702
bopper_702's Avatar
how difficult is it to do this disc break swap and the best option. im in the same situation on my c20..
i want to keep it a 8lug
bopper_702 is offline   Reply With Quote
Old 11-09-2012, 01:18 PM   #14
airdale94
airdale94's Avatar
You will need the booster, master cyl., and prop. valve off a 71-72 C20. Everything else can come off a 73-87. If you don't have power steering it's best to get everything. Tyrods, centerlink, idler and pitman arms, gearbox. For the suspension; lower control arms, springs, spindles, and of course the brake parts.The upper control arms are the same but you will need upper ball joints for 73-87. Chances are you'll have to have front brake hoses made. Or you can use the ones for drums if you get 76 and befor parts. In 77 GM went to metric threads on calipers, ps pump, and gear box.
Let me know if you need further info.
Old 11-13-2012, 09:07 PM   #15
mrich550
i would definetely stick with 8 lug & get parts off 72. however new replacement parts may be slightly more difficult to get. depends on your taste & budget. aluminum wheels off of the 2000 & up silverados are very nice looking on these trucks.
mrich550 is offline   Reply With Quote
Old 11-13-2012, 09:16 PM   #16
gcottingham
I'm more than fine with the 8-lug. I really just want disc brakes (front only is fine). And I would love to know what wheels would look good on there. Haven't seen pictures of newer wheels on an 8-lug, but that would be awesome.
Old 11-14-2012, 12:28 AM   #17
KrazyRay
KrazyRay's Avatar
I'm looking at a set of 20s for my 69 6 lug C/10. They were on a 2005 Chevy. I better test fit them before acquiring. Thanks for the info!
KrazyRay is offline   Reply With Quote
Old 11-14-2012, 03:03 PM   #18
orange rumble
orange rumble's Avatar
www.ClassicParts.com.....8 lug stock height disk brake conversion kit...spindles,rotors,dust shields,calipers,bearings,seals,dust caps,spindle nuts,banjo bolts,upper and lower ball joints,inner and outer tie rod ends,and tie rod adjustment sleeves...899.95 slotted and drilled rotors optional,75.00 extra.Classic parts of America 1947-1998 Chevy and GMC truck parts 1-800-741-1678.
orange rumble is offline   Reply With Quote
Old 11-15-2012, 08:40 PM   #19
THE DRIVER
I thought I saw everything when I saw the 8 lug rear disc conversions! wow, I'mm all over that, would require an all disc prop valve true? Time to do some research!
THE DRIVER is offline   Reply With Quote
Old 11-15-2012, 10:12 PM   #20
BAT
Why not just change the axels instead of the entire,rear end?
BAT is offline   Reply With Quote
