Where is your AD battery
53 AD with 5.3/4l60 Where is the best place for the battery under the floor in the stock location or move it to the firewall?
Re: Where is your AD battery
leave it in the stock place.. clean fire wall..
![]() Join Date: Mar 2007
I mounted mine to the passenger side frame rail behind the front tire. It is a SS drop down battery box.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#5 | |
We replaced the stock battery box with a SS drop down box................... but when we put the running boards on it will not drop low enough to remove the battery. I bet that is why you moved your box forward !!!!!
Batteries much larger than the stock six volt won't fit very well in the stock location and are often hard to get in or out.
I've had one on the firewall at one time and hated it. Ugly zit taking up room in the engine compartment that sometimes lets corrosive stuff drip on the nice new valve covers. Ok for a farm truck where you need easy access to the battery but not ok on a custom truck that you show with the hood open. This time around I'm planning to put a wooden tool box looking box at the front of the bed made of the same wood as the floor. It will hold the battery on one side and tools and other truck supplies on the other. That isn't for everyone I full and well know but I don't want the battery under the floor or in the engine compartment. |
This a 700 cranking amp bought at costco's and comes with a built in handle to lift it out.. works great..
My chevy 51...... http://67-72chevytrucks.com/vboard/s...d.php?t=541148 www.knutselracing.nl |
Under the cab floor,, I made my own , and hang it a little bit lower so I can take the battery out with no problem..
[IMG] ![]() [IMG] ![]() Posted via Mobile Device
#10 | |
Marc
the plow truck I had, it was on the firewall/inner fender, was easy to get at but didn't look the best, when I get a new one I will put it on the firewall also as I am not going for cosmetics.
2011 Silverado ECSB LT 2000 Silverado RCSB 2WD super bad habit of not owning a vehicle for a long time ![]() |
#12 | |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
I am putting mine under bed just behind cab pass side, will use a race car disconect so you dont have problem shorting when removing, also have remote battery access under hood for jumping or timming light
Fatbear 1952 yellow 3100 350 v8 on sonama frame |
Mine's frenched into the top of the passenger side inner fender.
There's alot of room in there! |
#15 |
pictures???
#16 | |
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#17 |
