Old 11-10-2012, 03:29 PM   #1
mexlokote
mexlokote's Avatar
overheating again
i recently fixed a leak on my inline six 250 4.1
the leak was coming from the thermostat housing neck,
so i put everything back together with new v-velts
i turned the engine on and left it running for 10 minutes
i checked the radiator and hoses if it was overheating because my thermostat guage i dnt think it works its aways on cold, (but has new thermostat)
but the radiator and hoses were cold so i though thats good, then i turned the engine off, one minute later the radiator and hoses started to get really hot,
the upper thermostat hose that goes to the radiator was leaking water with a lot of preassure really hot water
any ideas?
mexlokote is offline   Reply With Quote
Old 11-10-2012, 03:50 PM   #2
75chev4x4
75chev4x4's Avatar
Re: overheating again
Sounds like your thermostats opened up after you shut the truck off. Check your upper hose maybe the clamps are not sealing or you have a hole in the hose.
75chev4x4 is offline   Reply With Quote
Old 11-10-2012, 03:56 PM   #3
mexlokote
mexlokote's Avatar
will do that thanks for ur help
Old 11-10-2012, 06:38 PM   #4
mexlokote
mexlokote's Avatar
the upper hose is leaking, where the radiator is the clamp wont seal it all i tried the hardest i could , when i press on the hose air and coolant come out of the hose i dnt know why clamp is not sealing it has new clamp
