Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-10-2012, 08:09 PM   #101
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: New to me 1972 K5
I asked for the bird design ... It was better then a company logo... I guess they were built on a Friday. HA. I spoke to the owner and he's building me a new set...
The tank will be 13" deep to fit the factory fuel module. I also have a 1" body lift and the the frame is 4", so if I leave space for the fuel connections on top it should be about 8 to 9 inches below the frame.
Rich
1972 K5 Blazer CST Click HERE
Old 11-12-2012, 01:01 AM   #102
mcmlxix
mcmlxix's Avatar
Started the motor mounts for the LQ9 ...
Drive side fabrication ....
Passenger side in place waiting to be tacked..
Rich
Old 11-19-2012, 06:04 PM   #103
mcmlxix
mcmlxix's Avatar
Finish welded the motor mounts...
Test fit the NP205 to the 4L80e and had my friend Russ (the robot) tig weld the adapter...
Should have the gas tank cut on the waterjet this week....
Rich
Old 11-19-2012, 06:09 PM   #104
mcmlxix
mcmlxix's Avatar
Here are two pics of the big brake upgrade on the Dana 60.... Sorry I dont have the calipers installed yet, but you can the rotor fills up the 17" Hummer H2 wheel...
Rich
Old 11-27-2012, 10:16 AM   #105
mcmlxix
mcmlxix's Avatar
Ok. weekend update...
New crossmember for the trans/transfer case... boxed mounting plates to fit in the frame... I'm having a bracket cut on the water jet that will be bolted to the trans and welded to the crossmember...
Fox shocks hanging off the factory mounts.... I'll weld the lower mounts when the axle is centerd and pinion angle is set.
Here is the center console. I didn't really do anything to it this weekend other then take a pic. The very front still needs to be bent down. I have a hand e-brake to go in the center.... I just ordered some cable shifters from NWFab....
This is a set up for a doubler, I'll only have two shifters
the last pic is the CaptainFab booster mount and my new wire "harness" for the brake lights. I used a 90* fitting from home depot and I'm running 14awg 6 wire trailer wiring. I will be doing something custom with the rear lights...
Rich
Old 11-27-2012, 10:21 AM   #106
mcmlxix
mcmlxix's Avatar
I forgot to add that I picked up the fuel tank from the waterjet guy on Saturday too. It's not even bent yet so I didn't get any pics....
Rich
Old 11-27-2012, 07:46 PM   #107
MTCK
MTCK's Avatar
Progress is looking good!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-27-2012, 09:01 PM   #108
hgs_notes
GEARHEAD
hgs_notes's Avatar
Nice build. I like that console. Should look good with the transfer case shifters and e-brake handle on there.
hgs_notes is offline   Reply With Quote
Old 11-27-2012, 11:51 PM   #109
mud.man.rj
mud.man.rj's Avatar
Ya really like the console too, most don't even run one, good mod.
mud.man.rj is offline   Reply With Quote
Old 12-04-2012, 02:10 AM   #110
mcmlxix
mcmlxix's Avatar
Sunday update...
Back of 4L80e with a temporary brace. The six holes in the trans are not symetrical....
Here is a close up of the 3/8 plate that bolts to the trans/xfer adapter... It's welded to the tube crossmember and then boxed in... then some overall pics
Plent of room on the driver side for exhaust... none one the passenger side as the transfer case is clocked up and is only an inch from the floor...
Rich
Old 12-04-2012, 02:28 AM   #111
mcmlxix
mcmlxix's Avatar
Also finalized the rear axel... centered and set pinion angle ... new lower shock mounts and factory upper mounts... Not sure if I'll add a mount for the reserviors or just attach them to the shock body...
Russ cleaning the axle tubes... you can see the new mounts in bare metal and the factory mounts further out...
Here are the new rear spring hangers. The first set was not square and they also hit the body mount on the Blazer. The vendor was very easy to work with and built the new hanger and sent it out without hesitation. Kert at DIY4X is great and easy to work with. I have recomended him before and still will.
Here is a shot of the front of the driver side, springs mounted and shock tabs welded... 11" of travel on the Fox 2.0 shocks...
OH.. and here is a shot of the stainless steel tank... still flat with its protective plastic cover...
Rich
Old 12-05-2012, 11:08 AM   #112
boonedogs72
boonedogs72's Avatar
do you loan your buddy russ out????? haha nice work guys
boonedogs72 is offline   Reply With Quote
Old 12-28-2012, 07:16 AM   #113
mcmlxix
mcmlxix's Avatar
OK. Haven't updated in a while. The tank was a PITA... Too many bends on one piece, so we had to trim ends and weld them back on.. Also put a little too much heat into the ring... so the top is a little warped. Its tacked together...
Trying to track down a scrap piece of 2x4 to make a new rear crossmember. Replace the factory bolt in Z shaped bent one with a welded on length of box tubing...
I bolted up the hydroboost and built the connecting rod to the pedal. I cut and sectioned the brace from the firewall to the master cylinder (not pictured).
I posted this in my brake upgrade thread as well... but ....
I went to test the Raceline wheel on the passenger side and it fit, but barely. So close that I went and assembled the driver side (I hadn't tried this before.) I tride to mount the Raceline wheel and it wouldn't fit over the wheel studs. The problem was I upgraded to 5/8" wheel studs and holes in the rim was too small. It had no allowance for being 27+ years old and slightly off center. So I grabbed the Hummer rim and .. TA DA... it fit the driver side, no problem.... 1/16" celarance between the caliper and rim.... So now I was thinking, what the hell is wrong with the other side....
I disassembled the passenger side brakes, then re-assembled making sure everything was aligned. There is a small amount of adjustment/play in the hole that the caliper mounting bolt goes through. I test the Hummer wheel again, and IT FIT.... again only 1/16" clearance, but it clears... as long as there is no deflection in my braket, I should be fine...
Another note about the Raceline wheels. You have to use aftermarket slpined lug nuts. The fit was so tight that you couldn't even get a thin wall socket on the lugnut. Now that may be beacuse I upgraded to 5/8 wheel studs and the OD of the larger lugnut take up more space, but just and FYI.
Rich
Old 12-28-2012, 08:58 AM   #114
ryanroo
ryanroo's Avatar
I had wondered about that tank. it looked like it might be a real bear to break up. i wish you were closer, i could get you your scrap of 2x4 this morning! i used a few drops of that for cross members in my truck since we have a lot of it laying around at work.
are you planning on baffles for your tank? if not, i would strongly recomend them. looking forward to seeing it mounted!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-28-2012, 09:06 AM   #115
Jdubs71
Jdubs71's Avatar
Did you have to do any major modifications when adapting the 4l80 to the np205? That adapter looks sweet. I want to adapt my np205 to a 4l60 in my swap. Didn't know if there was a similar adapter for that. PS Russ has some mad welding skills
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 12-28-2012, 11:28 AM   #116
mcmlxix
mcmlxix's Avatar
I did split the main section in half... front to back.... had to leave space for the fuel lever float arm on the side...
... and I was politely told to consult my fabricator before making any engineering descisions... hahahah
Rich
Old 12-28-2012, 11:31 AM   #117
mcmlxix
mcmlxix's Avatar
nothing special at all... but my input shaft on the NP205 was correct for the output shaft on the 4L80e....
Rich
Old 12-29-2012, 02:07 AM   #118
trkfrk
trkfrk's Avatar
Nice work... Coming along good.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 12-31-2012, 03:29 AM   #119
mcmlxix
mcmlxix's Avatar
Sunday Update:
Started by bending a few brake line pieces... then I messud up and went out an bought some more.... moving on ....
When Russ showed up we installed a new rear crossmember to replace the factory one bent like a Z. Unbolted the old one and welded in a pices of 2x4 heavy wall box tubing. Dont cringe, but I cut off the rear frame horns too.... Well I didn't, I made Russ do it.... I just couldn't.... I'll have a custom bumper on the back anyway. I think I want to cap the farme rails from driver side to passenger side for a more finished look... but maybe just skipit as the bumber will be right there anyway...
After the new crossmember was installed, we mocked up the tank. We were making a front crossmember for the tank and I was cleaning the frame rail to weld it when .....
The tank fell off the stand from about 5ft in the air... hit the floor ... put a dent in the back of the tank... and destroyed the OEM GM Fuel Pump assembly.... It's 80% plastic and the force just shattered it. So now I have to spend $250 for a new pump... FML!
At this point I just celaned up a few tools, turned off the lights and left...
Rich
Old 12-31-2012, 03:57 AM   #120
MTCK
MTCK's Avatar
Good progress, sorry to hear about the tank - that sucks. Looks like you are getting close to lighting a fire. So which rims are you going to run?
-Marcus
Project Plow Truck
Old 12-31-2012, 05:01 AM   #121
mcmlxix
mcmlxix's Avatar
going to stick with the H2 rims.... after adjusting the brackets, they clear... barely... So we'll see if they need to clearance themselves under load... hahahaha..
The goal will be to replace the front hubs with new ones and run M14x1.5 wheel studs to match the late model disc brake rear... 5/8 front studs was overkill for what the truck wil lbe intended for...
Spyntec makes a forged hub with a higher then normal offset that will allow me to make caliper brackets out of 3/8 material instead of 5/16. I can then run normal M14 studs and run any aftermarket wheel without an issue provided they clear the 14" rotors and Dodge calipers....
Rich
Old 02-11-2013, 08:24 PM   #122
mcmlxix
mcmlxix's Avatar
Haven't done much latlely .. here are a few picture updates ...
Center console....
Rich
Old 02-11-2013, 11:10 PM   #123
mud.man.rj
mud.man.rj's Avatar
Nice idea on the shifter setup. All of them.
Old 02-12-2013, 03:49 AM   #124
mcmlxix
mcmlxix's Avatar
thanks...
I still need to figure out position for the twin stick transfer case levers... I have a console mounted e-brake handle to figure out and a digial trans temp gauge....
Also, the front piece in this pic is supposed to fold down.
Rich
Old 02-12-2013, 08:14 PM   #125
mud.man.rj
mud.man.rj's Avatar
So is the twin stick for one only t.case, which one a 205.
