Old 11-11-2012, 01:32 AM   #1
mexlokote
mexlokote's Avatar
brand new belt squealing
my 82 c10 250 4.1
has 3 belts just replaced with new belts
and the alternator belt is sqealing when i press on the gass
what can it be?
mexlokote is offline   Reply With Quote
Old 11-11-2012, 01:54 AM   #2
kris's66lwb
resident wrencher
Re: brand new belt squealing
Is the alt turning ? If not its seized. If that's not it is it flopping ? If so re tension it as tight as possible. If all else fails clean the belt groves in all pulleys. And then while its running thro some powdered borax soap on the belt. The grainuials will clean it out better. Or could be a cracked water pump pulley. My 350 had that high pitch chirp noise at high rpm
kris's66lwb is offline   Reply With Quote
Old 11-11-2012, 01:56 AM   #3
mexlokote
mexlokote's Avatar
the belts are tight as possible and yes its turning and i will try to clean it
Old 11-11-2012, 02:22 AM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Take the belts off and using a medium to fine grit sand paper, sand all the grooves of the pulleys then slightly scuff the sides of the belts to get a better "grip" on the pulley grooves. Replace,retighten belts and start it up. If squeeling persists, you've got bearings going out in the water pump or alternator or power steering pump. Maybe a.c compressor or A.I.R. pump if you have them.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-11-2012, 02:23 AM   #5
mexlokote
mexlokote's Avatar
alright i will clean them tomorrow thanks for ur help
Old 11-11-2012, 02:46 AM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Belt conditioner
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-11-2012, 02:47 AM   #7
mexlokote
mexlokote's Avatar
what is that
Old 11-11-2012, 02:56 AM   #8
INSIDIOUS '86
Exactly what it is. That being belt conditioner. While the engine is running you spray it on and under the belt and it makes the belt a little tacky. I use it on mine a few times every other month. Even with an underdrive my belts sqeel like hell if I Jump the throttle from idle at a light
It's also cool to use as a ghetto track bite for street racers but you didn't hear that from me
https://www.google.com/search?q=crc+...&client=safari
Old 11-11-2012, 02:59 AM   #9
mexlokote
mexlokote's Avatar
oh,,, already tried that and only stopped it for a few minutes then started again
Old 11-11-2012, 03:18 AM   #10
INSIDIOUS '86
Ah then yes you Definitly have something dragging somewhere. Pull the belt and spin everything by hand and see if a pump or alternator are causing excessive drag. Everything should feel smooth
Old 11-11-2012, 03:31 AM   #11
78maliburat
what brand of belt ?..get a ribbed belt
78maliburat is offline   Reply With Quote
Old 11-11-2012, 07:45 AM   #12
Boog
laying low
Boog's Avatar
Pulley misalignment will cause belt squeal also. If you have already sprayed the belts and found it immediately stopped the squeal but it came back after a minute or two then it is definately not a bearing issue.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-11-2012, 11:04 AM   #13
mexlokote
mexlokote's Avatar
belt brand is duralast
Old 11-11-2012, 11:33 AM   #14
blazer2007
Mine did it when was cooler,went to a different belt and is gone,read somewhere the shape of the belt and different shape of the pullys would make noise
blazer2007 is offline   Reply With Quote
Old 11-11-2012, 03:21 PM   #15
bilfman
bilfman's Avatar
Belt probably just is not tight enough.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 11-11-2012, 04:51 PM   #16
zaccaglin
zaccaglin's Avatar
Mine does it every couple of months on my 6.2l. I just retention the alternator belt then it
Goes away for a long time. Best to have someone else tighten the belts while you pull the breaker bar on the alternator back with all your mite.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 11-11-2012, 08:28 PM   #17
mexlokote
mexlokote's Avatar
turned out to be the powersteering box, it had missing 2 bolts, i bough new bolts and installed them and now there is no noise, thanks guys!
