Custom under bed Fuel cell ?'s
Has anyone made their own under bed Fuel cell for their stepside? I am looking into making one like the ones on summit. Does anyone have any dimensions of their under bed Fuel cell?
Lance, 2011 Subaru WRX, Hatch- Daily 1972 C10- Project |
![]() Join Date: Apr 2008
Re: Custom under bed Fuel cell ?'s
Lance,
Dont know how much trouble you are wiling to go to, but I used an Aeromotive 20 gallon cell. 24"x20"x10" deep. It definately wasnt a drop in affair, but I used Early Classics rear x-member that goes in flush with the end of the frame rails. I had to build a flange for the cell and then a frame to mount it to the frame rails. I also had to remove some of the lower flange on the angled x-member behind the rear axle. A slightly smaller cell would have been easier & it also hangs pretty low. I would have gone another route if I didnt already have the cell from another project. Do some searching here, there is a member that builds a nice cell that addresses most of the issues I ran into. Hope this helps, Shane |
I just mounted a 40 Gal suburban tank under the bed of my 71 4x4 long bed,,was not that much trouble as I cut all the cross members out of the Suburb and mounted them where the stock spare tire mounts,,turned out nice and now have 40 gallons to feed the Big block monster,,there is a thread going with video's I posted.
Future TOTM Winner
I'm in the planning stages of doing exactly that. Like Shane mentioned, mine will be basically 24"x"20"x10". I will have a rear sump with -8AN fittings so I can hook up to an external fuel pump. Also going to install either a fuel door or maybe the marker light filler modification.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Thanks guys,
I am just trying to weigh my options of wether I should shell out the money for a pre made one or make one. Critter, I am thinking of doing something similar to you and Shane, I am just trying to figure out the exact configuration I want to go with. Posted via Mobile Device
Quit if it's not FUN!!!
Not exactly under bed but _ _ _
. I finally got this set-up plumbed and working this weekend: . http://67-72chevytrucks.com/vboard/s...d.php?t=547782 |
2WD Jimmy
![]() Join Date: Mar 2005
Why would you need a fuel cell instead of a tank?
http://67-72chevytrucks.com/vboard/s...d.php?t=448431
This works.. although I don't really like how far it sits down to be able to have the fill tube through the license plate. I am modifying it to use a side fill through the side reflector. http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2 |
Tom,
I suspect we are getting into semantics here. I would actually call what I used an aluminum tank. A true fuel cell will at most basic at least have a safety bladder inside of it. My reasoning was based on my needs for the tank. I can do some mild fabrication so starting with something close was my best option. I also wanted to move the tank from the cab as the stocker was leaking. I also wanted something that had an electric in-tank pump for the EFI I will be running. Shane |
Here is the aluminum fuel tank I am putting in my 71 SWB
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
