Old 11-11-2012, 11:40 PM   #1
Hart_Rod
Hart_Rod's Avatar
CPP Sway bar question
I'm trying to figure out the correct CPP sway bar to use with my CPP lower tubular a-arms (67-72). Does anyone know if this is the correct one?
http://www.summitracing.com/parts/clp-cp7423/overview/
Thanks in advance.
Hart_Rod is offline   Reply With Quote
Old 11-12-2012, 07:45 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: CPP Sway bar question
That looks like the one I used with my CPP arms. I did have to use the different CPP sway bar frame mounts for lowered trucks, the bar only comes with brackets for stock height.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-12-2012, 07:58 PM   #3
Scottshotrods
The part number they have listed cp7423 we sell for $125.10 plus ups.This sway-bar is for 63-87 1 1/4 kit
Justin
(805)485-0382
Scottshotrods is offline   Reply With Quote
Old 11-12-2012, 08:44 PM   #4
Hart_Rod
Hart_Rod's Avatar
Thanks Adam. I already have the ECE lower mounts, I'm assuming they should still work.
Justin
(805)485-0382
Thanks Justin. How much to ship it and how long will it take to get it? Thanks,
Rob
Old 11-12-2012, 09:14 PM   #5
Scottshotrods
Rob
p/m sent
Justin
Old 11-13-2012, 06:03 PM   #6
jephs422
Thanks in advance.
Also, just for info, the 7423 is the only front sway bar CPP makes. the only difference is the brackets you'd get for them, whether they are the lowered brackets or stock.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
