Old 10-21-2003, 01:17 PM   #1
HeavyK20
HeavyK20's Avatar
Trans/T-Case Removal
Which method of transmission and t-case removal is easier?
1. Motor, Transmission and T-Case out the top
2. Transmission and T-Case out the bottom
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 10-21-2003, 01:57 PM   #2
Prerunner1982
Prerunner1982's Avatar
until i helped a buddy pull his 305 out, i thought taking the trans off in the truck was hard., it really wasnt. you can reach all the bolts fairly easily. i would try pulling it from the bottom if you have enough room.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-21-2003, 03:01 PM   #3
NAPCO ken
NAPCO ken's Avatar
put an engine hoist (cherry picker) through the open passenger side door, drop the chain down the transfer case shift lever hole, attach chain at the bottom of the tranny to transfer case adapter, and lower it down. Works really slick, and you don't have to worry about the thing falling off a tranny jack.
ken
'58 Chev NAPCO 4x4 short
'60 GMC Suburban 4x4, restored
'60 GMC 3/4T stepside 4x4
'64 GMC Suburban 4x4, restored
'90 Chev Suburban 4x4, dually, ZZ502
'77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s
'88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!)
'03 Jeep Wrangler Rubicon
'79 Chev 3/4 Suburban 4x4, 400-400-203
NAPCO ken is offline   Reply With Quote
Old 10-21-2003, 05:23 PM   #4
HeavyK20
HeavyK20's Avatar
I like the cherry picker idea, that sounds like It'd work good.
Next Question:
Should I seperate the transmission from the bell housing or take the whole assembly at once?
Eric
Old 10-21-2003, 08:06 PM   #5
NAPCO ken
NAPCO ken's Avatar
take the tranny off the bellhousing. leave the bellhousing to come out with the engine.
ken
