Help how to measure new drive shaft
Just did a swap from a th350 to a sm465 need help on the correct way to measure a new drive shaft.
Posted via Mobile Device Posted via Mobile Device |
Re: Help how to measure new drive shaft
Center of u-joint to center of u-joint.
If you are having a shaft made I'd recommend you contact the shop and ask them how they want you to do it.
I've showed up before with my own measurements and they made me go home and do it their way. (Shaft is still too short IMHO). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
a fool with no money
www.markwilliams.com has some good info on driveshaft measuring and setting angles. print out the sheet, write down all the measurements, fax, email, or go to your local shop, and like Keith said, hope they dont send you home for another measurement.
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
Watch out for your cornhole !
![]() Join Date: Jun 2003
My shop has me bottom the yoke into the transmission then pull it back out 3/4 of an inch. Then measure from center to center from there. This is all done with the truck at ride height.
my shop was exact same way
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Sweet thanks for all the help got the drive share measured and dropping it off at the shop today.
