Old 11-13-2012, 06:56 PM   #1
Mister-B
Ideas for cleaning up/replacing center caps?
What are my options for the center of the wheel, if I want to keep these wheels? Do they make some sort of center cap that installs? If not, what can I do clean it up? Paint it?
Mister-B is offline   Reply With Quote
Old 11-13-2012, 07:23 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Ideas for cleaning up/replacing center caps?
Here's an 88-98 8-lug center cap and trim ring on a steel wheel. I don't know, but maybe someone will know if those centers will work on your truck. They may not, but again they might. I was thinking about the trim rings for my Wheel Vintique 16x7's, but there is an ad on the 88-98 parts page if you're interested....they're in WA, so shipping would be less for you, than me.
Member Nr. 2770
Old 11-13-2012, 07:49 PM   #3
69GWC
Look like the same wheel I had on my 02 4x4 2500, they did come with caps kinda like he posted pix of but you will need lugs nut with threads on the outside for the caps plastic lugs to screw to.
I vote for a set of white wagon wheels, they look great with the blue and white truck like yours.
69GWC is offline   Reply With Quote
Old 11-13-2012, 07:54 PM   #4
Mister-B
Oh, I see. Cool. Thanks!
Old 11-13-2012, 07:55 PM   #5
Mister-B
Yeah, true. That might look sharp. I wonder what wheels this came with originally?
Old 11-13-2012, 07:57 PM   #6
69GWC
Probably a white steel wheel with a dogdish style of center cap.
Old 11-13-2012, 11:13 PM   #7
jocko
jocko's Avatar
if you want the factory cap on there - here ya go:
#CHVC31 (1st cap in the row that is third from the bottom)
http://www.hubcaps.org/chevtruck.html
Or - can go to the local junkyard and find em in spades - came on 2000's chev 3/4 tonners. Don't know the EXACT year span, but it's at least 01-06, possibly 99-06, and 07+ would likely fit but may look a bit different cosmetically.
I'm not certain chevloray's would fit since they are for steel wheels, but they certainly might and I really like the look of them even better.
Pic is from an 02 2500HD.
Old 11-13-2012, 11:16 PM   #8
jocko
jocko's Avatar
here is what your truck would have come with originally (or at least close) - this example is the 16.5" variety (a few different widths were available) - note the "bulging" center section of the cap, this indicates it's a 3/4 tonner for pre-73 trucks (or you could measure it's diameter if you had a ruler in person, bigger than the 1/2 ton caps). SPID code would be P03:
EDIT: Btw, the hubcaps.com place does NOT have the original polished 69-72 3/4 ton caps that they list on their site - trust me, I've called several times. They've been out for years. But they did have the nice restored white ones last time I talked to them.
Old 11-13-2012, 11:25 PM   #9
Mister-B
Thanks! I think I'll check the junkyard
Old 11-13-2012, 11:46 PM   #10
cubber
I would also check ebay, seems you can get stock center caps cheap on there, especially if they're from a really common wheel.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 11-14-2012, 12:41 AM   #11
Mister-B
Ooh. I like that.
Old 11-14-2012, 01:57 AM   #12
Mister-B
How much should they go for at the junkyard? Wanna make sure I'm not getting ripped off
Old 11-14-2012, 12:00 PM   #13
FirstOwner69
FirstOwner69's Avatar
I bought these. Genuine GM and brand new.
http://www.ebay.com/itm/170775505907...84.m1423.l2649
Also, the older caps in post #2 above will not fit your wheels properly, nor will the van and steel wheel caps made from 2001-2006 which appear nearly identical to those in the eBay link I attached to this post. The dual thread conversion lug nuts with the non-metric 1/2" or 9/16" threads are also available on eBay.
FirstOwner69 is offline   Reply With Quote
Old 11-14-2012, 12:29 PM   #14
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
You are going to need a dually cap for the rears. I had a pair of the same type GMC wheels and the standard cap would not fit.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 11-14-2012, 01:35 PM   #15
FirstOwner69
I know the standard caps fit fine with an Eaton and my Hummer H2 wheels. I also have some of the wheels we are talking about and seem to recall trying them a couple years ago on my Eaton without any problems. I understand only the Dana causes a problem. I know the 2001-2006 dually caps don't fit the wheels properly. I've tried the caps off my '06 dually and the O.D. is too big (way bigger than the van/steel wheel caps that also don't fit). The standard caps should work on the Dana with a spacer and longer wheel studs.
Do you have a picture of dually caps installed? How do you get them to fit properly?
Old 11-14-2012, 06:30 PM   #16
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I had a Dana 60. The truck is now gone and I never got caps for the rear.
