Old 11-13-2012, 10:07 PM   #1
GM-power
GM-power's Avatar
oil leak
Oil is leaking from somewhere by the distributer. What could it be? I've read it could be pcv. I haven't taken anything apart and it just started doing this a few hundred miles back. These leaks are aut to drive me mad. This is on a 350 on the LH side and drips down onto the bellhousing then onto the trans pan.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 11-13-2012, 10:44 PM   #2
dealrcn
dealrcn's Avatar
Re: oil leak
Is it coming from the distributor? Or at the oil sending unit at the back of the motor? Or is it the valve cover or intake manifold leaking? These are a few places to check first.
dealrcn is offline   Reply With Quote
Old 11-13-2012, 10:46 PM   #3
GM-power
GM-power's Avatar
Re: oil leak
Valve covers are fine, I can't really tell whether its the manifold or the oils sender its just. Hat area
Old 11-13-2012, 10:54 PM   #4
dealrcn
dealrcn's Avatar
Re: oil leak
I'm gonna bet that its the oil sending unit. I would spray it down good with some engine degreaser and clean that area really good. Then take a good look at it. Does it have a mechanical oil pressure gauge, electric gauge/light? Sometimes the sending unit or tubing fittings just need to be tightened but sometimes the sending unit will go bad and start leaking.
Old 11-13-2012, 11:00 PM   #5
GM-power
GM-power's Avatar
Re: oil leak
Mechanical in guessing its all stock.
Old 11-15-2012, 08:31 AM   #6
dwatts1984
Re: oil leak
Worst case scenario grab some UV die (11 bucks or so at auto parts places) and pour it in. The stuff Ive used in the past doesnt even require the UV glasses. Its pretty straight forward... Where you see green is where the leak is originating. I'd wait till you need to do an oil change though. Its safe to use in the engine... Just don't want your truck looking like its pissing ninja turtle green pee!
dwatts1984 is offline   Reply With Quote
Old 11-15-2012, 07:43 PM   #7
GM-power
GM-power's Avatar
Re: oil leak
Looked at somewhat close after I drove it. It kinda looks like its leaking where the opsu screws into the motor. Is this bad, or do I just need to get a new one put her in there?
Old 11-15-2012, 10:20 PM   #8
dealrcn
dealrcn's Avatar
Re: oil leak
If the sending unit is still working and it's just leaking at the block you can just take it off, clean it, put some thread sealant on the threads and put it back on.
Old 11-17-2012, 07:44 PM   #9
GM-power
GM-power's Avatar
Re: oil leak
Well I tightened the opsu and it still leaked. Turns out its the intake so im gonna live with the leak for a week till I get payed then get a performer intake and hopefully fix this leak.
