Old 11-14-2012, 04:02 AM   #1
SHANE 73Z
Cab mount cushion question
Hey all,
Im starting to install the Prothane poly cab mounts (1/2 ton truck) and have run into a question.
I noticed that of the 4 main cushions that 2 are slightly shorter/longer than the other 2. This discrepancy is only 1/8" and looking at the cast-in numbers they do seem to be different parts.
My only problem is Ive never seen a good stock set to know which position (front/rear) takes the appropriate height mount.
I searched & couldnt find anything regarding this situation. Can anyone shed some light on this?
Thanks in advance,
Shane
SHANE 73Z is offline   Reply With Quote
Old 11-14-2012, 11:24 AM   #2
dfwright
dfwright's Avatar
Re: Cab mount cushion question
Check out this post and see if it helps
It’s Just A Pickup
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 11-14-2012, 12:38 PM   #3
SHANE 73Z
Exactly the info I was searching.
Many thanks!
