Old 11-14-2012, 02:13 PM   #1
Sixteen Tons
Sixteen Tons's Avatar
Choke Plate - Monojet
Can anyone tell me what the piece in the center of this choke plate is, what it's for if anything, and is there anything additional missing from it? Finally, should it stay or should it go?
Sixteen Tons is offline   Reply With Quote
Old 11-14-2012, 04:07 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Choke Plate - Monojet
I'll look at mine to see if they have the same.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-14-2012, 04:26 PM   #3
68gmsee
Active Member
68gmsee's Avatar
It's for a vacuum break. Probably not needed if you have choke cable. Mine was un hooked. Scroll down this page for a parts break down.
Pics.
06 Trailblazer
Old 11-14-2012, 06:12 PM   #4
Sixteen Tons
Thanks for identifying that. I have not seen that illustrated anywhere else except on your link. My vacuum break just (exterior in picture) just passes through the rubber seal and terminates after about 3/4". I'm not presently looking at it, but I can't recall if it looked severed off or not. I do not have a manual (in cab) choke, nor is it electronic, I believe it is a bi-metal spring on manifold type. Am I actually missing something, like the rest of the shaft that connects to the choke plate? Or is this a 69 Monojet design change? I'd like to sort it out before I reassemble. Thanks again for the input.
