Old 11-14-2012, 03:53 PM   #1
mmsidaho
mmsidaho's Avatar
Pitman Arm Installation
I'm working on a 1972 C10 restoration I started several years ago, and I don't remember how far the pitman arm slides onto the splined shaft of the steering gearbox. In trying to install the new pitman arm, I can only get it to a point where there is still 3/8" to 1/2" of spine showing between the pitman arm and what would be a tight fit to the bottom of the steering gearbox. I've torqued the heck out of it with a 3/4" drive wratchet and socket and I blieve I've got the threaded end of the splined shaft coming out below the nut. I'm at work and don't have any pictures right now, but could take some later on.
Any idea if this is the normal spot where the pitman arm belongs? I'm almost afraid of what it might take if I have to force it any further up the splined shaft of the steering gearbox.
Thanks.
mmsidaho is offline   Reply With Quote
Old 11-14-2012, 04:39 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Pitman Arm Installation
The pitman arm/gearbox are tapered and it will only go in as far as the taper will allow it. Pics of mine. (The leak is from a bad hose I have.)
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-14-2012, 09:31 PM   #3
mmsidaho
mmsidaho's Avatar
Mine is on about the same amount now, so I should be good.
Thanks for the help and the pics!
Old 05-12-2016, 04:04 PM   #4
SIXT8LOU
SIXT8LOU's Avatar
hello! i know this is a old thread, but i am having the same issue on my truck, the pitman arm does not slide all the way up as it did with the old arm(im installing all new front end) i can see where the old one left its mark, and im still bout a 1/4 inch short of the old mark. i have a identical new replacement part (moog 6143). I appreciate your help if possible. thank you!
68 C/10 short bed
77 C/20 silverado long bed
05 GMC Duramax Crew
SIXT8LOU is offline   Reply With Quote
Old 05-12-2016, 05:54 PM   #5
slikside
slikside's Avatar
No experience with this, but it looks like it would be easy to put the arm on up-side-down. Make sure you have it going on the proper way.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 05-12-2016, 11:29 PM   #6
sprint_9
sprint_9's Avatar
Make sure you torque the nut, if you have power steering it is torqued to 180 ft/lbs.
sprint_9 is offline   Reply With Quote
