Old 11-15-2012, 04:52 PM   #1
Igorsgonemadd
Need a drip rail ASAP...and some advice
Ok so I pulled the drip rails off my truck for paint and in my hurry to get it to the body shop, I left the front drivers side on top of the truck when I pulled it off and it's gone now. So I need one badly What vendors sell them ! It's off an 87 crew cab, . Also a little confused about how to put them back on. When I got the little bolts out, which I had to do with needle nose pliers cause I couldn't get a socket in there, there was tape on the back side of it. Do I need to put something in between drip rail and the body or just bolt them up. Then should I run a bead of silicone around them to keep water out or do I need to use seam sealer. All help would be greatly appreciated. Thanks!
Igorsgonemadd is offline   Reply With Quote
Old 11-15-2012, 07:23 PM   #2
bilfman
bilfman's Avatar
Re: Need a drip rail ASAP...and some advice
2 sided body tape works good to hold them down and seal the holes, if not some seam sealer around the holes. Stay away from silicone on anything exterior.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
