Old 10-21-2003, 05:39 PM   #1
lotik
drag it like you stole it
wiper switch connection
i have a new wiper switch from LMC. there are three prongs on it.
1 on one side and two close together on the other. i can get a pic if it is needed.
i need to know what wire goes wire. btw, i have to run new wires. so there is no stock harness..
negative camber //LA\\
lotik is offline   Reply With Quote
Old 10-21-2003, 08:09 PM   #2
JimKshortstep4x4
Talking
Does no harness mean that your motor is not wired either?
Anyway, I am not sure how much this will help but here goes.
Looking at the switch with the two terminals that are close together on the left side as you look at it from the back.
first terminal black wire or windshield washer pump if you have no wires
second terminal dark blue wire or slow speed on your wiper motor
third terminal light blue wire or fast speed on your wiper motor
Jim
Old 10-21-2003, 09:21 PM   #3
lotik
thanks. which terminal is which on the motor? i wont be using the washer pump.
