Old 11-16-2012, 07:14 AM   #1
63burban4x4
63burban4x4's Avatar
suburban rear bumper brackets
Anybody know if the rear bumper brackets for suburban and pickups are the same? I think the bumper itself is suburban only, right? Also, are the brackets the same for 60-66? thanks
63burban4x4 is offline   Reply With Quote
Old 11-16-2012, 12:26 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: suburban rear bumper brackets
No, the rear brackets are specific to suburban and panels. Completely different from trucks.
Also, from what I know, there are 60-62 bumpers and brackets and 63-66 ones. The frame is a different width IIRC. It's not much different between them but enough they won't cross over from one to the other.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-16-2012, 05:03 PM   #3
64fleetside
The63-66 burb rear bumper bolts straight to the frame with no brackets, except the outer braces which are similar to the front bumper outer braces, but shorter.
64fleetside is offline   Reply With Quote
Old 11-16-2012, 06:04 PM   #4
63burban4x4
thanks. I've got an extra set of braces from a 64 sub I'll be putting up on the classified side, thought they were suburban only but I wasn't sure.
Old 11-16-2012, 06:17 PM   #5
64fleetside
I think panel uses the same as burb.
Old 11-17-2012, 07:59 AM   #6
63burban4x4
Right, I assumed that panel & suburban used the same thing. thanks
Old 11-17-2012, 01:11 PM   #7
63burban4x4
Re-reading this, I want to make sure I've referenced the correct parts. I know the 63 & up bumpers bolt right to the frame, did not know there was ever a "bracket" for that, sounds like the earlier had some kind. No matter, that's not what I'm asking about. Reading the replies, what I am asking about is (apparently) referred to as "braces", not "brackets". I bought a rear 65 suburban bumper (known to be, I removed it from the original truck) which includes the outer "braces". I want to verify that these are different from the pickup trucks, and only 63-up. Sounds like it, but just to double check. thanks again.
Old 11-17-2012, 10:25 PM   #8
chevy_mike
chevy_mike's Avatar
That is my understanding. The outer brackets/braces are '63-'66 burb/panel specific and are different than truck ones.
Old 11-18-2012, 07:57 AM   #9
63burban4x4
OK, thanks again.
