#26 |
![]() Join Date: Nov 2007
Re: Project 30 years sitting
Sadly, same motor if I dont eff the block up getting the dizzy out tomm.
![]() I cant really afford what I want right now..... 6.2 with the 4l80e and undecided tc. I just need to get it running, do some body work, and then decide where I want to take it. |
#27 |
Block out, dizzy out. Lots of sludge inside. Time to clean!!!
#28 |
pics of the mess.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
#29 |
#30 |
![]() Join Date: Jul 2011
Motor looks a heck of a lot better.
1969 C10 LWB GMC. 1970 K5 Blazer 1971 K10 Burb Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=529970 ![]() Shawn |
#31 |
Thanks. Motor actually looks like a motor after today. 14hrs and it honestly doesnt look like I got much done. But 2 trips to junk yard, and 3 trips to parts store will kill time quick.
#32 |
#33 |
It runs!!! Video soon
#34 |
#35 |
Damn, that was quick...well done
#36 |
4 days of nothing to do but work on it.
#37 |
GEARHEAD
Sounds good. Congratulations.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#38 |
Since Ive gotten it running, Ive been doing lots of piddly things.
Plumbed brake booster and pcv valve re-plumbed some of the fuel line (its going to get changed later though) installed elbow on power steering line have gas tank hanging in place (waiting tell weekend to weld braces) cleaned and tinkered with transfer case selector box. I think I have all 5 positions now. removed clutch peddle mounted fuel pressure regulator for elec tank installed new detent cable changed trans pan/fluid/filter installed dust shield for tq conv (it didnt have one) have the first few feet of exhaust routed. Cant figure out where I want to dump it. started on some body work testing my new stud-weld gun and slide hammer. |
#39 |
GEARHEAD
Its been a few days now. Where are the pics?
#40 |
Nice work on the motor. While working on a project it seems you almost put as much time running around to different places for parts and shopping on the internet. Also the research eats a lot of time too.
#41 |
Havent been taking pics as there is really nothing to see IMO.
Agree on running around, research, etc. Big snag today, went to back it out to weld on it and it wouldnt stay running. Turned it around yesterday and did just fine??? Compression test showed 6? to have zero compression. Yet will somewhat hold air when doing a leak down test. WTF? Rockers are moving as well. |
#42 |
Here is a pic from last night after turning it around, before I went out for the evening. Still in same spot, but has gas tank bolted and partly hosed up, also has drivers mirror on it.
#43 |
No clue what the motors problem was, but it started today and ran fine. So while it was running we did a quick tune on the carb.
Power wire routed but not hooked up for the tank 06an fuel line routed but not hooked up for fuel supply. |
#44 |
http://www.youtube.com/watch?v=SjleM...ature=youtu.be First drive heading out.
http://www.youtube.com/watch?v=Sa5LK...ature=youtu.be First drive returning |
#45 |
GEARHEAD
Just kidding with you. Its the common theme for all threads on this board. MORE PICS!!!
![]() Congrats on getting it down the road, and especially back again.
#46 |
You would think being a photographer, I would take out the good camera and be posting millions of pictures. But most of this is just cell phone shots
![]() I guess next time I'm under it I could get pics of all the sexy aluminum parts on the bottom side that will never be seen otherwise |
#47 |
Talked to previous owner today, he thinks he may have the original 205 transfer case that has a transmission tailshaft snapped off in the input. Hopefully I can get that off him
#48 |
Was under it measuring for mufflers, so I snapped this. Looks like tonight will be a wiring night to upgrade the size of wire for the HEI, and wire in the fuel pump.
#49 |
I have a dis-assembled 205 transfer case on my floor. YES. When I'm feeling better I will sort everything out to figure out what I need n have. Time to find a diagram.
:edit: Figured out is a dana 20, dangit. Last edited by Dale99; 12-12-2012 at 09:24 PM. |
#50 |
Productive day yesterday....
Frame horns fixed with parts from a board member I got a while back. Pass door hinges replaced from a board member I got a while back. rear shocks installed due to frame horns getting fixed, I could finally bolt down the front and install fenderwells with bolts I got from board member Brian A. This morning I ordered my tires ![]() plan to work on my exhaust more, rewire my fuel pump relay I fubar'd. Maybe get the grill installed. Depends on how many people come help. |
