11-17-2012, 08:38 PM | #1 |
dash extender
I have seen many trucks with lower dash extensions are these custom built or can they be purchased somewhere? I have a 59 apache and would like one if they are available.
Thanks for any help
1955 2nd on 86 chassis Daily driver |
11-17-2012, 09:35 PM | #2 |
Re: dash extender
A photo of what you are looking for might help guys come with something. Years ago I saved a piece that goes under the dash of an early 70's Ford Maverick that has a couple of cubbie holes to stick stuff in. It's still out in the shed somewhere where it's been for 25 years. I don't know of much in the aftermarket but you might look under the dashes of cars and trucks out of the early 70's to see if there is a panel that can be removed and modified. International travelalls (sp?) come to mind for some reason.
11-17-2012, 11:36 PM | #3 |
Re: dash extender
Lynx5653
I had my lower dash panel made out of steel. I also reshaped the bottom of then dash so it goes straight across. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-17-2012, 11:38 PM | #4 |
Re: dash extender
I've often heard these called a "valance" and all I've seen are custom made.
11-18-2012, 12:01 AM | #5 |
Re: dash extender
I have also seen some made out of paneling and such that you would use for upholstery. Then they cover them in the same material as the rest of the interior.
Marc
11-18-2012, 12:23 PM | #6 |
Re: dash extender
11-18-2012, 07:02 PM | #7 |
Re: dash extender
mine is home made out of fiberglass
the base is cardboard mailing tube and plywood held together with hot glue gun and staples
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-19-2012, 08:50 AM | #8 |
Re: dash extender
that looks really nice, wish I knew how to do fiberglass work. I really like the cover for steering column. Might try youngrodder's aproach and use a piece of metal, his look nice also.
Thanks for pics
11-19-2012, 10:06 AM | #9 |
Re: dash extender
here is pics of my lower dash extensions.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
11-19-2012, 10:43 AM | #10 |
Re: dash extender
Dan-
Here are a few pics that show my dash better. [IMG][/IMG] [IMG][/IMG] Basically I cut the bottom of the dash off that dips down (where the ignition switch and other stuff where located). Then I welded in new metal to fill the void. This just allows for a straight across piece of metal for the lower panel. I have seen it also done where the dash is left in tack and the lower dash panel is contoured to fit around the factory dash where it dips down. Make sense? Marc
11-19-2012, 12:38 PM | #11 |
Re: dash extender
Perfect sense. Thanks!
Do you own a sheet metal brake? Us that how you made you extender/valance? Have it don't by others, or maybe weld up from flat sheet? Posted via Mobile Device |
11-19-2012, 01:14 PM | #12 | |
Re: dash extender
Marc
11-19-2012, 07:08 PM | #13 |
Re: dash extender
Thanks Marc,
I notice therre is no link to a build thread in your signature so I did a search on your name for threads you'd started. I found plenty but none of them are really a "build thread". I like your truck so much I wondered how a "young rodder" could build something so nice? Then I saw you'd mentioned its been an 11 year build so I'm wondering if your last name is "Young" or if you WERE young when you started the build? Maybe 12 years old?!! ha ha. I am curious just how good/bad condition your truck was in when you began because she's nice as can be now. HUGE congrats on such a nice ride. - Dan |
11-19-2012, 07:26 PM | #14 | |
Re: dash extender
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
11-19-2012, 10:47 PM | #15 | |
Re: dash extender
Good detective work...No build thread. Yes I was much "younger" when I started the project. I was in my late 20's and most of people my age were not into street rods so that is what gave me the idea for the name. The truck was a driver when I bought it but looking back I didn't use/keep much of the original truck. This project was started prior to being married and prior to my (2) boys being born. For these two reasons the truck budget took a hit. I also did myself no favors going with air ride and a fuel injected engine to name a few. All that is left is to finish the interior which I will be working on now until spring. Any other questions, give me a shout. Thanks for the kind words. Marc
11-19-2012, 10:54 PM | #16 | |
Re: dash extender
Marc
11-19-2012, 11:02 PM | #17 |
Re: dash extender
The ones I've seen are the vintage air kits that are premade for 47-53 trucks. Or later if you have the later model. People will paint them to match the dash.
11-19-2012, 11:06 PM | #18 |
Re: dash extender
That's what I have now and it just looks...well....plastic.
11-19-2012, 11:13 PM | #19 |
Re: dash extender
You could always do like mine, rip out the dash and start over making it long and clean.
11-20-2012, 06:30 PM | #20 | |
Re: dash extender
check out the interior build link in my signature easy peasy
11-20-2012, 06:38 PM | #21 |
Re: dash extender
That's pretty slick KPdalton. It's one way to fix a hacked up dash were someone chopped it up to put a head unit in at some time or other damage that dashes seem to get in the name of modifying.
I had exhaust tubing bent to make a new dash for the 48 back in the 80's but it didn't turn out the way I had hoped. Several guys took the idea and ran with it and turned out some really nice dashes over the years though. I've saved a dash out of a car I used to have that will get modified to put in the 48 now. I replaced that dash with a near perfect one out of a parts car and saved the old one.
