#626 |
Re: 1967 Chevy CST aka "the loud truck"
well shawn these next pics are for you!
before and after |
#627 |
C/10 junkie
Very nice Rick and it looks so familiar!!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#628 |
rattle can for now to see if i like it.... and i like it! just need to sand a couple spots down and re shoot it then i can put everything back in.
i also redid the fuel line. the old one came out real far and wnet outside of all the AC brackets and was in the way of my AC compressor belt. so heres a shot of the new line it toucks behind all the brackets and hugs the block |
#629 |
C/10 junkie
Looks good, what color and brand of paint did you use? Do you think it will match up to mine well? For touch up of course...
#630 |
Junk Yartist
Glovebox door came out nice!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#631 |
thanks guys! happy thanks giving to everyone!
#632 |
~it might match up top yours. it is rustoleum spray paint and on the can it says "GLOSS CHERRY". did the red on your dah fade really bad? or is it still pretty red? if its still pretty red then i should match but if its faded really bad to more of an orange then it probably wont blend in very well.
#633 |
well my transmission has realy been bothering me latley so im going to get another 350 transmission today and clean it up put new filter/gasket and fluid and install it
#634 | |
C/10 junkie
#635 |
Junk Yartist
just leaking or is it not working right?
#636 |
Jeremy. My transmission at 10 mph wants to shift into 2 but just revs up the Rpms on the engine and doesn't shift until 20 mph. At 20 mph it just goes into 3rd gear. So I have no 2 gear on my transmission. That an it's leaking lol. The new transmission doesn't leak and it works properly so i will put my new modulator canister on it and fill it with new fluid then install it. Coolest thing is that the new tranny was made January 24, 1972! So now I can get rid of the square body part on my truck haha
Posted via Mobile Device |
#637 |
pictures! i cleaned up the new transmission since it was black from grease. and i cleaned up some of the AC lines under the hood. heres one half clean and half not. and a couple pics for fun!
also shawn where are the pictures you posted? |
#638 |
C/10 junkie
What pics are you refering to Rick?
#639 |
Out of curiosity did you consider doing the 700R4 conversion instead so you would have Overdrive?
#640 |
you said " Well I'm not sure, you saw it what do you think?
#641 |
yes but my dad forgot to tell me that this 700r is from a 87 chevy van and has not been converted to a manual speedo cable... so that plus my drive line problem is why i am not putting in the 700r... lol dads are wonderful sometimes
#642 | |
What driveline problem are you refering to? |
#643 | |
C/10 junkie
#644 |
Yeah I loved the patina on mine to! The paint is close! I would use it but I would try to blend it with that section that your trying to paint.
#645 |
Well the new transmission has alot more pep and the speedometer works with this one lol.
That's being said...... This transmission isn't shifting into 2 gear or 3.... It just revs... So I'm going to try a different vacuum source. If that fails then I'm going to try adding a little more fluid. ( I'm probably not full but not really low I only put a gallon of fluid in) If that doesn't work then I will take a look at the govenor. If that looks clean an not messed up no dirt then I'm going to try the new filter an gasket and modulator canister And if that doesn't work then I'm screwed Posted via Mobile Device |
#646 |
C/10 junkie
The torque converter I think hlolds 5 quarts and the tranny holds 7. Sounds like you may just need some more fluid.
#647 |
Ok Shawn thanks ill try adding more fluid!
#648 |
Well it shifts!! It works! This transmission was taken out of a 72 along with the engine from my brother because he blew the engine up. It sat on the floor from 2003 or 2004 and now like 8 years later it's working perfect. Just goes to show that you can't kill a Chevy!
#649 |
well heres a pic from this morning before school. shes back on the road again!
#650 |
im gonna do a couple things to the 67..... its a suprise
