Old 10-22-2003, 07:14 PM   #1
rage'nrat638
rage'nrat638's Avatar
Ram Horn Heat Riser???????
GOT THIS BABY FROM A GUY THAT DID NOT KNOW WHAT IT WAS FOR
i could tell just by looking at it....
got it for $5.00
rage'nrat638 is offline   Reply With Quote
Old 10-22-2003, 07:16 PM   #2
rage'nrat638
brand new...from 20 years ago
Old 10-22-2003, 07:18 PM   #3
rage'nrat638
another
Old 10-22-2003, 07:46 PM   #4
ddsmith
Glowing since 1978
ddsmith's Avatar
Great score. That should make those cold morning starts work better. I think that is one piece that is usually gone on these old trucks. It rust away and no one every seems to look at replacing them.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 10-22-2003, 08:01 PM   #5
dinnut
dinnut's Avatar
thats a good find. i have never seen one before.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-22-2003, 08:09 PM   #6
Southpa
Southpa's Avatar
oooh, I could sure use one of those. I have the complete setup, heat collector and snorkel but my collector is in rough shape, still works tho. The odd thing is mine is on the driver's side manifold.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 10-22-2003, 08:15 PM   #7
rage'nrat638
i have never seen one before this ....
i tryed it on both exhaust manifols ...LEFT/RIGHT fits both????
i just figured it went on the passenger side...
but now i know.....thanks southpa
Old 10-22-2003, 08:58 PM   #8
Southpa
Southpa's Avatar
Oh, and I think you need one additional piece. There should be a thin plate that fits around the back to help hold the heat in. You can see the holes on the bottom of your unit for screwing it to the backing plate
Original 350/TH350
Old 10-22-2003, 09:02 PM   #9
rage'nrat638
cool i should be able to make it from some flat stock alum i have on hand....
i will trace the out side ,,,,and cut it out,,,.to match
Old 10-22-2003, 09:08 PM   #10
rage'nrat638
maybe thats why its flared on one end too...
is to catch the air and push it to the air tude....
so by looking at it it would be the drivers side
Old 10-22-2003, 09:19 PM   #11
bigvinnie
bigvinnie's Avatar
are you going for originality or do you just not like electric chokes..???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 10-22-2003, 09:25 PM   #12
Southpa
Southpa's Avatar
I used to have one of those K&N air filters, truck ran like crap on cold days and took forever to warm up. This stock unit feeds warm air directly into the intake off the manifold, best swap I ever made. I also like my manual choke much better than electric. I prefer anything thats going to make my truck run better over things that just look "cool" like the K&N.
Original 350/TH350
Old 10-22-2003, 09:26 PM   #13
rage'nrat638
just do not like electric chokes..
leaky headers
hard starts in the cold
Old 10-22-2003, 09:48 PM   #14
Denny
Denny's Avatar
I hate electric chokes also. I probably have the only Demon Carb in the country that is manual choke. I run a 1991 Chevy truck airfilter that I added a second snorkel on with a K&N filter with prefilter and have 2 home made heat boxes on my Hooker headers for the winter, In the summer I run a open element airfilter with 4" tall K&N with a prefilter on it.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-23-2003, 12:46 AM   #15
ddsmith
Glowing since 1978
ddsmith's Avatar
Electric chokes are no substitute for the hot air this setup provide when it's cold outside. In a non heated setup the fuel atomizes coming through the carb but pools out on the floor of the intake manifold which is cold. When you provide warm air the fuel has less chance to pool out on the intake manifold floor. This warm air is only provided until the engine is providing it own heat that is enough to prevent fuel pooling. Just for information. The factory setups that used an electric choke typically had the heat stove also. The electric choke would heat up and fully open in a couple of minutes. If you disconnected the heat stove supply to the air cleaner. The vehicle would run like crap cold and would stall because the choke came off to fast to help until the engine reach a decent operating temp. At least that has been my experience.
Old 10-23-2003, 05:17 AM   #16
71-longbed
Its Magically Delicious
71-longbed's Avatar
makes sense ddsmith .... it explains why my truck would sort of shudder on the way to work last winter ... only about a 5 minute drive....and i dont have a heat stove ... the PO took it off for some reason ...im just glad it doesnt get really cold up here
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 10-23-2003, 10:12 AM   #17
palallin
I have one still, but it's boxier--all squared off.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-23-2003, 05:46 PM   #18
Hugger
Hugger's Avatar
I'm still not sure how thats going to work on the drivers side, because, the snorkel runs up from the front half of the manifold, if you put this one on the drivers side, the snorkel is going to have to turn more toward the drivers side to reach it...
Anyway, still great find!!
72 LWB - Hugger Orange
350/350 3.73
Next; 335hp GM Crate
Hugger is offline   Reply With Quote
Old 10-24-2003, 06:45 PM   #19
Don Smith
Some people have all the luck. I have been searching for one in decent shape for years. I made one for mine but would like a factory one.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
