11-22-2012, 02:09 PM | #1 |
4" lift?
I have a 1966 GMC 3/4 ton 2wd with coiled springs in front. I wanted to know what the easiest and cheapest way to lift the front 4". Thanks for any help.
11-22-2012, 02:37 PM | #2 |
Re: 4" lift?
Get a 4x4 frame?
11-22-2012, 02:45 PM | #3 |
Re: 4" lift?
I was hoping to lift it some how without getting a 4x4 frame.
11-22-2012, 02:52 PM | #4 |
Re: 4" lift?
Making a pre-runner truck?
11-22-2012, 03:03 PM | #5 |
Re: 4" lift?
I"m trying to level the truck. so maybe 4" is to much maybe 2" is better. I was just wondering if taller coil springs were available. I want the stock 4x4 look without having to do the conversion. I'm kinda green at this stuff.
11-22-2012, 06:49 PM | #6 |
Sb 400 club
Re: 4" lift?
Find some one who makes coils in your area. Had a guy near me make some for a 98 amigo for 2 inches of rear lift. Ran me $200. Also keep in mind you will need longer shocks, brake lines and steering may need attention.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
11-23-2012, 12:24 AM | #7 |
Re: 4" lift?
JC Whitney I think still has lift coils for older trucks would be another option.
11-23-2012, 02:12 AM | #8 |
Re: 4" lift?
I think you may find that if you put a longer, "lift" coil spring up front that the upper control arm will be nearly sitting on top of, and maybe touching, the upper coil bucket on the 2wd crossmember. There won't be any room to install the rubber bump stop. You will have very little droop and when going over a big bump the UCA will hit the upper coil bucket, making an unpleasant slamming sound.
I installed 3/4 tons HD springs in my 64 1/2 ton chevy shortbed pickup (the HD have a larger diameter coil and a higher spring rate) to get as much lift as possible front and back. This didn't even come close to leveling the truck out, and I feel that my front suspension is just about maxed out. It simply wasn't designed to operate at that geometry. I think you'd have to do what the later model chevy truck guys do and make some custom spacers to drop the entire front crossmember down, relative to the frame. I'm not trying to be a downer, but I think that is the reality of the situation. What kind of springs do you have in the rear of the truck?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 11-23-2012 at 02:15 AM. Reason: spelling and grammar |
11-25-2012, 12:07 PM | #9 |
Re: 4" lift?
i guess it really depends how much time and $ tyou wanna put into it.
